Future proof kitchen connections
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Mon, Aug 11 2014 7:29 PM
Hello all
I have a BV7 in my main room sending SD to my bedroom beovision3 over ariel and Masterlink.
today I purchased a Bv6-26 from eBay with no DVI or HDMI just to be able to access the SD and ML from the rest of the system. I am going to run in the cables this weekend to connect the TV to the rest of my setup but I wanted to make sure I run some future proofing in also while the ceiling is down.
i will run in
CAT6a for ML ( is this OK)
power
ariel cable
I wanted to protect for the future, what do you recommend in case i change the system. Should I run 2xcat7 (NETLINK, HDMI over cat7 and the above?
I am hoping the sound from bv6 will be enough as I have a music room for loud music but I can never rule out some speakers active or passive.
Your thoughts would be great :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
Please do run the second cat cable too!
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Tue, Aug 12 2014 6:50 AM
If you have the space, drop in some of that coiled trunking you can buy in rolls. Make sure you tape the fish wire onto both ends.
Page 1 of 1 (3 items) | RSS
