Hello all
I have a BV7 in my main room sending SD to my bedroom beovision3 over ariel and Masterlink.
today I purchased a Bv6-26 from eBay with no DVI or HDMI just to be able to access the SD and ML from the rest of the system. I am going to run in the cables this weekend to connect the TV to the rest of my setup but I wanted to make sure I run some future proofing in also while the ceiling is down.
i will run in
CAT6a for ML ( is this OK)
power
ariel cable
I wanted to protect for the future, what do you recommend in case i change the system. Should I run 2xcat7 (NETLINK, HDMI over cat7 and the above?
I am hoping the sound from bv6 will be enough as I have a music room for loud music but I can never rule out some speakers active or passive.
Your thoughts would be great :)
Eclipse 65V1-32Beosound M5Essence MK2BLI
Please do run the second cat cable too!
If you have the space, drop in some of that coiled trunking you can buy in rolls. Make sure you tape the fish wire onto both ends.
