Problem displaying ConfigTool on Netbook
This post has 12 Replies | 3 Followers
Griebel
Posts 416
Griebel Posted: Mon, May 7 2012 8:13 PM
I have tried using the ConfigTool on a Netbook (Asus Eee PC) with Windows 7 32, but once the program loaded, the screen doesn't show the tool bar, while the program seems to work well (no error message and the update is done correctly and the Beo5/6 drivers OK).
This is the first time I have this problem. I have used the ConfigTool extensively on several different OS (XP, Vista 32 and Windows 7) and computers.
I've tried changing the displaying parameters, but didn't help, the tool bar never shows up.
Anyone had similar problem?
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, May 11 2012 12:36 PM
Did you try to set the display text size to 100% instead of the default value auf 125%.
The tool only works correct with 100%
hfat
Griebel
Posts 416
Griebel replied on Fri, May 11 2012 7:50 PM
Checked the text size, which is 100%, but the problem remains.
Any other idea?
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, May 11 2012 8:00 PM
Could you please post a screen shot. I'll try to reproduce on my PC
hfat
Griebel
Posts 416
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, May 12 2012 8:57 AM
It seems to me that the screen resolution is the problem: the minimum the tool works correct is: 1024x768
hfat
Griebel
Posts 416
Griebel replied on Sat, May 12 2012 4:57 PM
I tried different resolution, but it didn't help. It's really weird because the software seems working (it updating the database each time I connect), but the screen doesn't show the toolbar!
Real mystery to me, especially since it works on my other PCs (under XP, Vista 32 and Windows 7 on desktop).
Griebel
Posts 416
Griebel replied on Sat, May 12 2012 4:58 PM
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, May 12 2012 6:38 PM
I experimented with a lots of different settings, but wasn't able to reproduce the situation on my pc. It's strange because it seems that only the hight of the window is wrong. The widht is OK. Do you use version 5.11 of the tool?
hfat
Griebel
Posts 416
Griebel replied on Sat, May 12 2012 11:02 PM
Yes, I use the latest version of the Config Tool.
hfat
Vienna, Austria
Posts 663
I just was able to reproduce the problem. It is caused by the screen resolution, where the widh is OK and the hight is to small (my example 1200 x 650).
What is the resolution, you use?
hfat
Griebel
Posts 416
Griebel replied on Sun, May 13 2012 5:53 PM
Works in 1024 x 768! Was in 1024 x 600 before.
Thanks a lot for your help!
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, May 14 2012 5:53 AM
Great
Page 1 of 1 (13 items) | RSS
