Hello everybody,
how do you remove residues of adhesive from prastic or acrylic without damaging the surface beneath? The perspex covers of the flat panel speakers are fixed with double sided foam tape. Without removing the residue it seems hard to get them fixed again. Additionally they are painted from the inside which makes it an even harder task. Any hints?
Thanks very much!
Kai
I used white spirit to remove old foam and adhesive from the glass panels and frames from my BeoSystem 4500 after getting it recommended by other BeoWorld members. Works like a treat! Just let it soak in, and the foam and adhesive should literally fall right off! And the paint was not affected at all. Just be sure to degrease the surfaces properly before you start reattaching the covers - I used glass cleaner.
/Dennis
That's the way to do it Dennis. Piece of cake.....
Brengen & Ophalen
Thanks Leslie and thanks Dennis. I will have to do that shortly and since the Beolab 5000s are in really excellent condition I do not want to damage anything. Great work on your covers Leslie!
Greetings,
No probs Kai, I was planning to respond on your email but Dennis gave you the answer already....
No worries my friend. Your work and knowledge is highly appreciated.
Cheers,
If you get some scratches in the paint on the inside, just fill them with black paint. It will not be visible from outside.
//Bo.A long list...
Or nailpolish...
