Removing Residues of Adhesive
This post has 7 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Thu, Aug 21 2014 12:44 PM
Hello everybody,
how do you remove residues of adhesive from prastic or acrylic without damaging the surface beneath? The perspex covers of the flat panel speakers are fixed with double sided foam tape. Without removing the residue it seems hard to get them fixed again. Additionally they are painted from the inside which makes it an even harder task. Any hints?
Thanks very much!
Kai
Dennis
Denmark
Posts 627
Dennis replied on Thu, Aug 21 2014 8:50 PM
I used white spirit to remove old foam and adhesive from the glass panels and frames from my BeoSystem 4500 after getting it recommended by other BeoWorld members. Works like a treat! Just let it soak in, and the foam and adhesive should literally fall right off! And the paint was not affected at all. Just be sure to degrease the surfaces properly before you start reattaching the covers - I used glass cleaner.
/Dennis
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Thu, Aug 21 2014 9:03 PM
That's the way to do it Dennis. Piece of cake.....
Brengen & Ophalen
Manbearpig
Posts 908
Thanks Leslie and thanks Dennis. I will have to do that shortly and since the Beolab 5000s are in really excellent condition I do not want to damage anything. Great work on your covers Leslie!
Greetings,
Kai
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Aug 21 2014 9:57 PM
No probs Kai, I was planning to respond on your email but Dennis gave you the answer already....
Brengen & Ophalen
Manbearpig
Posts 908
Manbearpig replied on Fri, Aug 22 2014 10:09 AM
No worries my friend. Your work and knowledge is highly appreciated.
Cheers,
Kai
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Aug 22 2014 10:47 AM
If you get some scratches in the paint on the inside, just fill them with black paint. It will not be visible from outside.
//Bo.
A long list...
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Aug 22 2014 5:09 PM
Or nailpolish...
Brengen & Ophalen
Page 1 of 1 (8 items) | RSS
