BeoRemote One now available.
This post has 166 Replies | 8 Followers
Scott Needham
Paris, France
Posts 217
hello,
has anyone played with some of the more exotic commands from the beo4 ?
for example, I use link-av to listen to music in a link room from my bv7.
can you assign this sort of thing as a source ?
thanks !
- scott
Chris Townsend
Qatar
Posts 3,531
And a glimpse of the future with the year 2414 BeoRemote 97
http://www.firebox.com/product/6679/Star-Trek-Original-Phaser-Universal-Remote-Control
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Dec 4 2014 6:29 PM
Here is the new BeoRemote One in SILK to avoid fingerprints (right side):
Anybody know if it's available WITHOUT the Avant?
Regards
Räuber
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Dec 4 2014 6:33 PM
Raeuber:
Regards
Räuber
Will definitely go for silk once available.
beosound
Posts 91
This morning I bought a "silk" Beoremote. And yes, it works with my BV11-46!
beosound
Posts 91
Millemissen
Flensborg, Denmark
Posts 14,680
'it works with the 11-46'.
Does that include the three MyButtons?
PhilLondon
London
Posts 3,637
Have you set the Beoremote in Beo 4 mode?
According to the user guide, in that mode, the 3 MyButtons can be set to start 3 customisable sources (but not set the speaker/stand).
The Info and Guide buttons should however remain inactive in Beo 4 emulation mode.
p.
Beoworld app with direct photo upload and emoticons.
StUrrock
Posts 995
StUrrock replied on Thu, Dec 4 2014 11:04 PM
Millemissen:
Yes you can set 3 favs manually
Millemissen
Flensborg, Denmark
Posts 14,680
So - it does not work like with the Avant!
Michael
Sweden
Posts 2,578
Michael replied on Fri, Dec 5 2014 1:09 AM
I can set my Beoplay V1 to BeoRemote one mode so surely this can be done with a BV11 too.
In translation from Swedish:
Menu - settings - product integration - remote - BeoRemote one (or beo4,5,6)
beosound
Posts 91
Yes, you must set the BV11 to beoremote one. And the three buttons can be assigned as you wish, You don't need to set the beoremote it self to any other mode than the default out of the box. If you wish to use the remote for older products, then see the userguide.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 5 2014 9:26 AM
If it's possible to set BV 11 to Remote One the MyButtons should work like with the Avant.
If you want tu use Remote One with older products you must set the One to Beo4 mode. Then you can assign the MyButtons to a source (DTV, DVD, VMEM etc.). Does anybody know how you have to set the older Beovisions (Beo4 WITH or WITHOUT navigation key)??
Regards
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
I wrote above:
"it does not work like with the Avant".
This is true!
The spectacular and great thing about the MyButtons is, that you - with one push - can store exactly the settings/source etc, you want/need to one of them.
If I were only able to (manually) assign three different sources to those three button, I'd fix three small labels to attach to the buttons with the source name printed - or stick to the good old Beo4 (which has source names on the buttons by default).
To use the Remote One with a BV11/V1 like with the Avant would presume a software update of these tv's!
Michael
Sweden
Posts 2,578
Michael replied on Fri, Dec 5 2014 11:16 AM
Millemissen:
I wrote above:
This is true!
MM, the BVA/BV11/V1 all share the same software platform with online updates and support for BeoRemote One was rolled out earlier this year as a free software update. I believe the MyButtons works just as well with BV11 and V1.
Millemissen
Flensborg, Denmark
Posts 14,680
'I believe....'
Can anyone confirm this?
Michael
Sweden
Posts 2,578
Michael replied on Fri, Dec 5 2014 11:52 AM
Millemissen:
' I believe.... '
When I get home. It would be very strange if they would not work since you can chose that you have the 'one'...
Millemissen
Flensborg, Denmark
Posts 14,680
Looking forward to the answer!
Michael
Sweden
Posts 2,578
Michael replied on Fri, Dec 5 2014 1:35 PM
Yes, I´ll check as soon as I can. I have a 90km way back. BVA/BV11/V1 all share the exact same software update number so I think they all share the same features for the 'MyButtons'. Why would they not work when they have support for the BeoRemote One?
Anyway I will make sure to test it so you know 100%.
PhilLondon
London
Posts 3,637
Michael,
I think the confusion comes from the fact that people on this forum have for long time speculated that this SW update would be available one day, and that it apparently happened, and no one talked about it!
I would be good to check if the Info and Guide buttons have an effect when using a PUC controlled set top box.
p.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Dec 5 2014 4:38 PM
I´ll check when I can. Decided to stay here so I can go to the cinemas tonight and see Interstellar. (More science after been watching the Orion mission today.)
Millemissen
Flensborg, Denmark
Posts 14,680
Take your time - and enjoy.
I will be away most of the day tomorrow.
KMA
Posts 621
KMA replied on Sat, Dec 6 2014 2:28 PM
Finally – and by most information early.
The "official" (or should I say "mass") release date is still Feb/Mar 2015...
I chose the Silk version. Unboxing shortly, I'm still teasing myself fondling the box Stick out tongue
Kind of like a little bit of early Christmas. Very happy about this!
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
mjmedlo
Posts 922
mjmedlo replied on Sat, Dec 6 2014 2:44 PM
I've had 2 here in the US for several months.
It does take some getting used to but overall I enjoy it.
The my buttons are somewhat of a novelty imo.
I find I don't used them.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Dec 7 2014 6:54 PM
Millemissen:
Now I have had a chance to try and YES it works. I tried storing MyButtons-profiles on my bedroom V1 (just holding down one of them for a second or so) and that works too. Everything seems to work as usual.
I also took the time to connect my Avant55 & V1 together via the integration function and it works really good. Now I have Net radio (WEBRADIO) on my V1 through the Avant. It all works over the ethernet/network connection. In the source list on my V1 I now have nine sources local + 14 linked sources.
elephant
AU
Posts 8,219
Michael:
Millemissen:
Fantastic good news
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
Hello Michael,
thanks for testing!
I stand corrected Embarrassed
But I am very happy, that I - and others - have learned a thing or two from that Lets have a Party !!!
And thanks for your desription of how the two BV's work together - far too few people reaiise how good NL is!
Michael
Sweden
Posts 2,578
Michael replied on Mon, Dec 8 2014 2:13 PM
Millemissen:
Hello Michael,
thanks for testing!
No problem :). They work good but it is only audio that is transmitted unfortunately. I suppose it would be possible to send the picture also albeit reduced in quality.
PhilLondon
London
Posts 3,637
Michael:
NL only supports audio.
Video can be distributed through HDMI, and is therefore reserved for external sources (set top boxes, etc..).
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 8 2014 6:27 PM
Source: HomeMedia on the BV11-55 and plays on the BV11-46 in the living
(Just an example)
elephant
AU
Posts 8,219
elephant replied on Mon, Dec 8 2014 10:04 PM
Carolpa:
(Just an example)
So video IS transferred ?
Including FreeToAir ? STBs like Sky ?
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
It is the album CSNY1974 playing - music, no video!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Dec 9 2014 4:55 AM
format BR Audio with no video just some pictures
I ripped it to 192 kHz 24 bit FLAC though
NL does not support distribution of video for the moment
Millemissen
Flensborg, Denmark
Posts 14,680
Neither did ML!
NL could - but there are so many restrictions on distrbuting video, that it probably would not be worth the go. To much video, that - for this or that reason - is not allowed to be distributed.
The 'work-around' is HDMI/HDMI matrix.
But - do we really need video through NL - most video sources are local anyway. And some are available through DLNA (or AirPlay) streaming.
Millemissen
Flensborg, Denmark
Posts 14,680
Michael:
Would be fun to see a picture, that shows all those sources in your Source List on the tv(s) - if possible?
KMA
Posts 621
KMA replied on Thu, Dec 25 2014 1:06 PM
The BeoRemote One Silk version is absolutely beautiful.
The finish is immaculately smooth to the touch and doesn't get fingerprints or smudges. I'm really glad I didn't get the "natural aluminum" version, which seems to show more signs of use as I've seen at dealers'. The Silk version is, in my opinion, what BeoRemote One should have been from the start.
After a little practice, it's possible to use the basic functions of the remote without looking at it. The buttons have a shape to them, and at least my fingers are sensitive enough to distinguish buttons when gliding my thumb on them.
The possibility to easily rename devices, sources and functions is a big plus, especially coming from Beo5. Controlling BV11 and connected devices (and BeoPlay A8) is a joy – I couldn't be happier as far as remotes go!
KMA
fredpert
Posts 103
fredpert replied on Thu, Dec 25 2014 1:13 PM
I saw both remote when visiting my B&O dealer, I still prefer the polished version. Sure the silk one will not mark fingerprints, but the feeling is very "cold" and lacks sensuality and warmth you get when you touch the polished one. Just a question of personal taste I suppose.
FREDPERT
BeoVision 11-46 full black - BeoRemote One
KMA
Posts 621
KMA replied on Thu, Dec 25 2014 1:30 PM
fredpert:
The feel of the Silk version reminded me of the "cold" feel of Beo4, which I had for years before Beo5 – probably also one of the reasons why I prefer the Silk, besides the Silk version being fingerprint resistant.
On the other hand, the look of the polished version would have been more in line with the polished frame of BeoVision 11 and the covers of BeoLab 11...
You're right: it's a matter of taste. So it's good that there is choice Smile
KMA
jans
Belgium
Posts 394
jans replied on Thu, Dec 25 2014 10:36 PM
KMA,
Nice to hear you like the new BeoRemote so much. I see you are coming from a Beo5. Can you given us some insights why you prefer the BR1 over the Beo5?
Merry X-mas
Jan
Aussie Michael
Melbourne, AU
Posts 3,730
I love the BeoRemote One too - i don't have the satin version just the normal version.  I have found that it doesn't attract finger prints - maybe cos that I have not used it that much lol.  The satin / silk version looks great.  Thanks for posting the pictures.  I also find that renaming devices is also a good feature.
Page 4 of 5 (167 items) < Previous 1 2 3 4 5 Next > | RSS
