Pentas with extra subwoofer
This post has 16 Replies | 1 Follower
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Sun, Sep 7 2014 4:36 PM
Hi everybody,
I have a pair of Penta´s in my living room.
I would like to add a subwoofer.
Is my only option the Beoab 2, or will a Beolab 11 add some extra punch to my setup?
My dealer is offering me a demo-used Beolab 11 for my Beogram 9500 and My Beogram 6500 with a MMC2.
Is this a good or bad offer?
olvisab
Posts 1,391
olvisab replied on Sun, Sep 7 2014 4:57 PM
Hi
The deal seems to be good. However I really wonder if the bl11 is powerfull enough for adding extra Bass with a pair of penta. If your pentas works perfectly, I don't think it worth to choose a bl11
Do you plan to use them for surround sound and movies ?
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
leosgonewild
Helsinki, Finland
Posts 2,373
I am planning on using it for both music and movies.
I have another pair of Penta´s that I had as rear speakers for movies, but I removed them as there is almost no bass reproduction from the back. I put a pair of Beolab 4000 in the rear instead.
My only consideration is that with the Penta´s in the front, there are already 8 x 5" woofers. Will the 2 x 6,5" in the Beolab 11 really make a difference? I know that they are in a closed box, and that the pent´s have reflex tubes, but still..
Barry Santini
New York
Posts 543
olvisab:
Hi
Do you plan to use them for surround sound and movies ? beosound 5/BM5 , beosystème 4500 , beolab 1, beolab 5000, beolab 14, beolab 3500, beovision av 9000, IWS 2000, beotime, MLGW
I've tried this, as well as using a larger, no BnO sub, and found it unsatisfactory.
B
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Sep 7 2014 5:33 PM
I would be surprised if the bl11 made any difference to pentas, but do try before you buy/swop.
olvisab
Posts 1,391
olvisab replied on Sun, Sep 7 2014 5:38 PM
Someone with a pair of pentas with a beolab 2 will probably give you his opinion.
For stereo forget it but for movies, maybe it is an option. I had pentas and beolab 2 but not at the same time. I remenber that my house didn't tolerate them at all. Too much boomy bass.
But in the right environment the combination could do miracles.
leosgonewild
Helsinki, Finland
Posts 2,373
I´ll ask my dealer if I can try it.
Doubt he will let me try it home, he knows I am getting my B&O the cheapest possible way.
Anyone using Beolab 2 with their pent´s?
olvisab
Posts 1,391
olvisab replied on Sun, Sep 7 2014 6:57 PM
Lol, buying cheapest as possible doesn't mean you will steale it.
He should be proud that you would accept to buy a new or recent product.
francis
Posts 72
francis replied on Fri, Sep 19 2014 1:36 PM
Don't know if it's still relevant.
I once tried BL 11 with my Penta, connected to BV 10 with BL 6000 as rears.
Horrible experience, sound was dramatically worse with that combo, both music and video.
I have no experience with BL2, but at least for music I would not expect improved sound quality
DMacri
United States
Posts 881
DMacri replied on Wed, Mar 13 2019 12:05 AM
Does anyone have a final verdict of a good subwoofer (B&O or not) that will work well with Beolab Pentas? I would want something to provide support from 20Hz to around 40Hz or so.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
leosgonewild
Helsinki, Finland
Posts 2,373
I would use a Beolab 2, but would run the Pentas from the source, not from the Beolab 2.
Beofile7
Posts 150
Beofile7 replied on Wed, Mar 13 2019 10:55 AM
I had just that. Beolab 2 with Pentalab 2's. there was a marked bass increase but I really don't like subs at all so it didn't last long with me. If you like loads of boomy bass for movies it could work but for music it was just too much. A Beolab 11 will be useless.
DMacri
United States
Posts 881
DMacri replied on Wed, Mar 13 2019 12:46 PM
I just want to fill in the extreme lows for music, not movie effects. It doesn’t have to be B&O if there is a good performer - new or used - that could do the job without breaking the bank. Anyone had success with a pairing?
Dom
Stereomensch
Posts 322
Has anyone tried to combine the Pentas with a cona subwoofer?
leosgonewild
Helsinki, Finland
Posts 2,373
I have. It doesn’t do anything good.
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Mar 13 2019 9:12 PM
I use Penta3s/ BL4000s with a Beolab 2 - wonderful with the TV (Avant CRT DVD) but not so good with music. So I use my other system in the room to play music - Beogram 4000, Beomaster 4401 and M100s.
Peter
DMacri
United States
Posts 881
DMacri replied on Sat, Mar 16 2019 12:56 AM
Ok, so do I even really need a subwoofer when using 4 Beolab Pentas for surround music? Are they “full range” enough for a room that’s 15’x17’x10’? Geoff had previously mentioned subwoofers are not desirable for music listening, so maybe I should hold off on a purchase for now.
Dom
Page 1 of 1 (17 items) | RSS
