Beovision 7 Mk2 electronic curtain
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Sun, Sep 7 2014 5:08 PM
Hi everybody,
When I turn on/off the tv function, there is an electronic curtain.
When i turn on/off the DVD there is no electronic curtain.
Neither do I have the electronic curtain when using DTV (ATV3 that is always on).
Am I missing a setting, or anyone have a suggestion?
dayvinci
Posts 2
dayvinci replied on Thu, Sep 22 2016 6:54 PM
I almst have the same issue with my Beovision (
I have no curtain opening or closing. It switches off like a normal tv
could anyone be of assistance. I have reset the TV but nothing
Cheers
dayvinci
Posts 2
dayvinci replied on Thu, Sep 22 2016 6:55 PM
Hi, i have a similar issue with my beovision8, i have no curtain closing or opening. i also reset the tv but nothing. any suggestions, cheers
leosgonewild
Helsinki, Finland
Posts 2,373
On the model I had, the electronic curtain only worked on analogue sources.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Sep 22 2016 8:22 PM
If you're using the DVI socket as a source input, you will lose the curtains.
If you're using the internal DVD, or Scart Input you should get curtains when you turn it off....
Lee
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Sep 22 2016 8:24 PM
dayvinci:
The BeoVision 8 has HDMI input. Are you using this?
If so, you should have the curtains from memory.
Lee
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Fri, Sep 23 2016 10:26 AM
There's no curtain function on the dvi socket even with the latest SW 7.94.
I will see if it will work with a bv7-32 mk3 after updating to SW 30.08 which is only for TVs with hd-module Installed but is reported to work also with TVs without the module Installed. It should also bring some new features.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Page 1 of 1 (7 items) | RSS
