dear all,
i was wondering if anyone might have an old MCL expander that they are no longer using? I've been after one for quite a while. I actually saw one for sale once and passed it up, not realising they don't surface very often. I'm moving house and need to add a couple more rooms to the setup...
many thanks
luke
You may not need an expander?How many rooms(link kits) are you using.
I found that you could often run more link kits than specified without problems.It's more to do with power supply than data,you can even add a local supply at the furthest link kit.
Otherwise you can use active links perhaps for your extra rooms?In that case the kits are powered locally,so don't load the central system.
Are you planning long cable run's?
Regards,
Nick
Dear Nick,
Thanks for your reply. I'm currently running the MCL system from my Beomaster 7000. I have Beolab 6000 speakers in my main room, and use the Beomaster's amplifier to power 4 link rooms (2 MCL2a and 2MCL2av). In my new house I'd like to add another 2 to 3 rooms to that setup. I'm interested in the idea of using local power supplies; presumably I'd just connect a 7v DC supply to the MCL box instead of drawing power from the Beomaster? Do you have any wiring diagrams or further details of how I could proceed without the expander?
Many thanks and best wishes
Luke
Hello Luke.I don't expect you to have any problems with power supply to your proposed link system.The problem might be more to do with data supply.
All the link boxes are effectively connected in paralell,but as two of the new ones are locally powered (MCL2AV)this will lessen the load on the Beomaster supply.
In practice,I've experienced very few problems with MCL systems,it's simple and robust.You won't damage anything by connecting up the system as you plan to.The worst that could happen is that remote commands could be slow from link rooms.Keep all the mcl cabling as short as possible.B&O recommend max mcl cable in a system at 150mtr.
I have all the original installation notes,and a circuit diagram for the MCL expander,it's quite simple,and could be made up if you encounter prob's,but I doubt that you will.
