BC 2 dvd problem
This post has 4 Replies | 0 Followers
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 Posted: Wed, Sep 24 2014 6:41 PM
I have what I believe is a BC2 dvd version. Is there any way to confirm it is a dvd version ?
I tried playing a dvd and all I got was the sound track, is there some options I need to set ?
It is connected to a BV10.
Secondlife
Posts 145
Does your black box have a scart connected to your tv?
Dave Farr
France
Posts 2,283
Dave Farr replied on Wed, Sep 24 2014 6:47 PM
If you enter the menu settings, the 6th option down should be DVD.  Check the settings entered for Scart input to the TV etc.
Dave.
valve1
Posts 1,502
valve1 replied on Thu, Sep 25 2014 10:34 AM
Sorted, scart plugged in .... just not tight enough.
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Sep 25 2014 11:52 AM
valve1:
Big Smile it's amazing how often a Scart socket is the problem.  As you had sound but no picture it was the likely culprit.  Glad it's sorted.
Dave.
Page 1 of 1 (5 items) | RSS
