I have what I believe is a BC2 dvd version. Is there any way to confirm it is a dvd version ?
I tried playing a dvd and all I got was the sound track, is there some options I need to set ?
It is connected to a BV10.
If you enter the menu settings, the 6th option down should be DVD. Check the settings entered for Scart input to the TV etc.
Dave.
Sorted, scart plugged in .... just not tight enough.
valve1: Sorted, scart plugged in .... just not tight enough. Thanks
it's amazing how often a Scart socket is the problem. As you had sound but no picture it was the likely culprit. Glad it's sorted.
