BV6-23 to Gen3 AppleTV Flicker?
This post has 17 Replies | 1 Follower
AndrewEcosse
Posts 77
AndrewEcosse Posted: Sat, Oct 4 2014 8:09 AM
Having given up trying to get my MacMini connected to my BV7 to talk to the BV6. I've moved onto connecting a Gen3 AppleTV to the BV6 via the DVI using a HDMI to DVI adapter.... but I now get a flicker on the screen. About every 2 seconds the TV flicks. When it is not flicking the picture is perfect. The tv is connected as a link TV if that makes any difference to anything. Also in the connections menu I don't seem to be able to change anything??
Any thoughts please??
Thanks, Andrew.
elephant
AU
Posts 8,219
elephant replied on Sat, Oct 4 2014 10:23 AM
I some times get flickers but it is the occasional screen transition. I think it's an ATV software issue with complex scenes at 1080. I am using Hdmi to HDMI
BeoNut since '75
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, Oct 4 2014 12:11 PM
It could be a problem with hdmi handshake. If flickering is pesristent you could try following:
Enter customer service menu by highlighting option in menu and pressing red+go
Activate picture settings
Set value for framelock to nearest line
This is working for me as I had the same problems
hfat
AndrewEcosse
Posts 77
Hi, I think it might be something to do with the TV not being a HD model. The Apple TV works fine with the BV7 we have. When I goto to the service menu I don't have an 'Activate Picture Settings'??
I've played about with the apple tv resolution settings but with no luck.
It's odd as the whole screen flicks and then returns to normal for a moment.
Thanks for the suggestions so far...
steve1977
Posts 911
AndrewEcosse:
What were you trying to accomplish? I may have just ordered a PUC to accomplish same what you were trying, so hope that it may work?
AndrewEcosse:
I may have the same issue, but can live with it. When switching to my macmini (connected with hdmi-to-dvi adapter), I am getting a full-screen flickering for 2sec. After the 2sec, it disappears and all works well. I was told that it is just that these old BV models came from a time when DVI was still in early stage. But given that it is just 2sec and only when switching to the macmini, I am fine and can live with it. If you find a way thought o get rid of it, it would be appreciated if you can share back.
StUrrock
Posts 995
In one of the hidden menus there may be a setting to change the prefernce type of the DVI socket to HDMI, on occassion this has worked for me on Bvis 7s MK I II.
AndrewEcosse
Posts 77
From what i've been reading its the AppleTV that is punting out a format the TV cannot cope with. So that's a dead duck. I might think of getting a Gen1 ATV as that has component out.
Anybody know of a device that will convert dvi to scart???
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 5 2014 12:55 AM
Have you tried setting the ATV to output 720 ?
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 5 2014 12:58 AM
Steve ... If you are getting a PUC for your MacMini then I think you will need to get some additional OS X sw ... Once Apple retired front row it was less easy / useful and hence my preference for the ATV
BeoNut since '75
steve1977
Posts 911
elephant:
This would be horrible news. I actually need the MacMini and not just an ATV - to run xbmc and other apps. Any way how to get the PUC working? What additional software would be required and did you get it working in the end?
steve1977
Posts 911
Any more insights on above? Really no way of using BV5 PUC with MacMini witout additional software? What additional software will be required? Thanks in advance!
AndrewEcosse
Posts 77
Sorry i'm a bit lost with the abbreviations, by PUC do you mean the codes for the TV to control the MacMini via the IR? If so then, then they can be installed. At least on the BV7 they can. But as has been said with no FrontRow you'll need something like PLEX installed. It has a preference that can get it to launch with the menu button on the AppleRemote being pressed. On my B&O remote, it's the exit butting. There after it's fully controllable from the remote. PLEX is infinitely better that FrontRow ever was.
Does that help at all?
elephant
AU
Posts 8,219
elephant replied on Thu, Oct 9 2014 11:26 AM
steve1977:
Sorry ! sometimes by iPhone posts don't make it across the internet when I am whooshing through train tunnels !
I suggest you take a look at this ....
https://www.iospirit.com/labs/candelair/
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Thu, Oct 9 2014 11:32 AM
AndrewEcosse:
I use PLEX, however I have the server function on the MacMini, and I run the client on an IPad, and then I AirPlay from the iPad to the Apple TV.
I ended up with that solution after OS X lost Front Row ... up to that point I was able to use the IR PUC from the BV to the MacMini - and have the BV translate the IR codes from the Beo4 to the Apple Front Row / Apple TV codes - including the MENU key which is equal to the Beo4's EXIT key.
Before I settled on PLEX I did try XBMC, however I found PLEX easier to install, maintain, and run.
BeoNut since '75
AndrewEcosse
Posts 77
It's great, i've the same set up with the mac mini as the server, but it also has the Plex HomeTheatre installed, hence I can control it with the Beo4. For everything else on the mac mini I use MousePro on iPhone or iPad. The theatre will run on the exit key being pressed.
I tried remote buddy but found it very confusing, compared to using MobileMouse
http://mobilemouse.com
steve1977
Posts 911
steve1977 replied on Thu, Oct 9 2014 12:06 PM
Brilliant, this is a bit relief. I am trying to accomplish the same that AndrewEcosse is doing. Just with XBMC instead of Plex, but this should not make any difference as they basically use the same keymap.
I am looking forward to my PUC to arrive and then manage XBMC through my Beo4.
AndrewEcosse
Posts 77
Hi Steve, when you say waiting on your PUC to arrive? Is it not a command loaded onto the TV? XBMC looks good. Is there a command in it to allow it to run from a remote input?
Thanks, Andrew.
steve1977
Posts 911
steve1977 replied on Thu, Oct 9 2014 12:47 PM
Yes, it is typically loaded in the television. I still have a BV5, so quite an ancient television. Something needs to be installed and it is being shipped from Denmark. I am not sure what this really is, but it is the same thing that you are referring to.
Page 1 of 1 (18 items) | RSS
