I search it also urgently!
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
So do I.
riishoj@gmail.com
It's now impossible to put any IR third party comand on a macro ?
I have made any change for Cinema ON :
0:000:TV:CINEMA_ON
Delay:3000ms
0:000:LIGHT:CIFFER_0
ON-OFF
The ON-OFF is a third party command to switch on my Sanyo 3000 projector. Before the 6.84 config tools there were no problem and now, the ON-OFF command isn't accepted anymore (when I clic on the ADD button, nothing happen)
It's a little bit strange because 0:000:LIGHT:CIFFER_0 which is a Lutron third party comand as no problem and is accepted as before.
Thank you for your help if there is anyone who make special comand with configuration tool.
It was mentioned that the new sofware doesn't support 3rd party commands on the hardbuttons anymore - which is a very dumb move from B&O!.Maybe they kicked the 3rd party functionality out of the macros, too!?This is the reason why I do NOT update to the newest software: I will loose functionality of the Beo 5.
Can you provide me the link to download this new version?
Could I also have a download link please?
Hi, Can someone please send me a copy of the new configuration tool? I tried the steps listed on the previous page, but I keep getting an error message with my e-mail. I would really appreciate some help.
So how did you guys get the new CT? there are no links and most people beg to get it...
Can you kindly send me the New Configuration Tool version 6.84, for Beo5/Beo6 to me?
I dont think more than a few ever got it :(
I have bought ct 6.84. Saving configuration on windows 10...64 bits to beo6 driver error. Firmware is 3.30. Original first configuration was made on 32 bits windows xp. What to do.....I have no more xp and like to have it work on 64 bits windows 10.
Beovision 10-46, Beo6, Beosound 5+ Beomaster 5, Beolab 12.2, Beolab 12.3, Beocom 6000
May I ask for an email-Attachment or a link ?
Thx,
Tom
I have no link to website where you can download the CT 6.84.
No PM for me :( this ct6.84 seems to be quite elusive :(
As told I have no link. Bought the CT 6.84 from someone. So yes I have the tool, but its private as I paid for it. Sorry!!
As told I have no link for CT 6.84 to some website.
Hello, I'll be grateful if you tell me where I can download the latest configuration tool. I tried to search in the web without any success....
Hello Keith, Where may I download the latest configuration tool for my beo6?
here you are
http://archivedforum2.beoworld.org/forums/t/21026.aspx
Thanks Beozip!
Where can i get the new Configuration Tool version 6.84 for the mac can you help me to send me the link or software
The configuration Tool was only designed to run on a Windows operating system.
Regards Keith....
Hi Keith,
when i connect my beo6 on my pc i het A error on my USB poort, i have Windows 10 64 bits is that A problem.
It can be, generally speaking its best to use it on a 32bit XP system - I have a virtual mashine for just that. But not all config tools run on 64 bit, what version have you tried installing?
Alibaks:when i connect my beo6 on my pc i het A error on my USB poort, i have Windows 10 64 bits is that A problem
On Windows 8 and 10 you will need to install the USB driver manually. Have a look at my answer HERE for Windows 8/8.1
Regards
Kiran
Born in NL; I ride ML
Just download it from http://www.mediafire.com/file/6s2l3qs88zqz9x1/CTSetup_6.84.exe
If you only own a Mac, there is no reason to invest in a Windows laptop just to use the config tool. You can run any Windows VM on a Mac easily using a program like that http://www.parallels.com/products/desktop/. This is what I do.
Having never used Windows on a Mac with no CD drive. How do I add Windows to Parallels once I download it - or does it already come with it?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Hi, could you be so helpfull and send me the version? Thx a lot
My Bang & Olufsen....
Can anybody send me a link to download this software CT 6.82 ?
https://www.mediafire.com/file/am3t5arg7c8d22e/CTSetup_6.62.exe/file
I only have 6.62 and 6.84
Here is the 6.84 version: https://drive.google.com/file/d/0BzY5RcNnTvKSOW05b0w0amtYMU0/view
