BeoConnect not connecting...
This post has 15 Replies | 4 Followers
Griebel
Posts 416
Griebel Posted: Mon, Oct 27 2014 9:44 PM
Have been using BeoConnect for some time on several laptop and desktop PC computers. Now suddenly on one of them (running Windows 8) BeoConnect is no longer connecting to the BeoSound5/BeoMaster5. It detects the device on the network, the IP is fine, but connection doesn't happen.
Uninstalled and installed the software again, but didn't help. Surprinsingly, after a fresh install, it keeps the old configuration with BeoSound5 on the list of selected device (!?), meaning that the uninstall did not clean all the parameters.
Anybody any clue how to solve the problem?
TWG
Posts 1,672
TWG replied on Tue, Oct 28 2014 6:02 AM
Did you set a username/password on the Beomaster for the connection?
Griebel
Posts 416
Griebel replied on Tue, Oct 28 2014 7:46 AM
Yes, but it doesn't seem to be an authentification issue. BeoConnect works fine on all computers except one and I'm trying to figure out why!?
Griebel
Posts 416
Griebel replied on Tue, Oct 28 2014 9:11 PM
Still not working on one computer running Windows 8. The BeoSound5 parameters are correct, but BeoConnect does not want to connect to the device. I'm quite sure that the problem comes from a network option which prevents the computer to connect to the BS5, but which one???!!
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Oct 30 2014 4:09 PM
Same here.
Wanted to demonstrate how to connect between Beonnect and the BM5 (without BS5) for a customer.
So I changed the password in the BM5 menu to show how to connect.
Beoconnect finds the BM5, asks for the (modified) password, but doesn't connect.
Several times restarting or changing the password inside the BM5 (service)menu, doesn't work.
So, would a software-update be responsible for this bug?
I never had this before.
PC, laptop or Macmini can't connect with the BM5.
Beobuddy
Posts 3,972
Beobuddy replied on Thu, Oct 30 2014 5:44 PM
What worked for my was changing the workgroupname via the service-menu.
Griebel
Posts 416
Griebel replied on Thu, Oct 30 2014 9:22 PM
Changing the workgroup won't help and after all BeoConnect works fine on several of my other computers. One is resisting and I'm trying to figure out why.
When I ping the BeoMaster5 using DOS command on that particular computer it works fine, but once in Windows it doesn't connect anymore.
My guess is that there is something in the network parameters that prevents BeoConnect from talking to the Beomaster5, but what?
Barry Santini
New York
Posts 543
when I had this years ago, I was using an older home router. Try changing the router.
B
Griebel
Posts 416
Griebel replied on Sat, Nov 1 2014 8:32 AM
The router is fine. It was installed one year ago by my BO dealer, based on the official recommendation (a Cisco). Moreover, if the router was the problem, my other computers wouldn't be able to connect via BeoConnect to BM5/BS5.
nico vercammen
Elversele, Belgium
Posts 174
May be a problem with the firewall settings of windows 8 ?
Try to turn the firewall off in the control panel to test.
Nico
Griebel
Posts 416
Griebel replied on Sun, Nov 2 2014 6:07 PM
I appreciate your help, but alas it's not the firewall. When I turn the firewall off, I still can't connect.
Compared the network configuration with that of another of my PC running also Windows 8, which has absolutely no problem connecting via BeoConnect. Couldn't figure out any difference. I'm clueless...
Beobuddy
Posts 3,972
My router is only a few months (Linksys 6900) old. So that's not the solution.
Beside restarting the BM5 and changing the workgroupname, I also installed the Beoport software, as I have a PC Link2 active box installed.
Did you change your workgroupname? It might have something to do the way the pc's trust/rights on the same network.
For me the problems started by changing the passworg inside the BM5. Entering the same password at Beoconnect didn't work. Before that, it worked flawless. Strange behaviour.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Nov 2 2014 8:23 PM
goto
Control Panel\Network and Internet\Network and Sharing Center\Advanced sharing settings
change the homegroup connections
Griebel
Posts 416
Griebel replied on Sun, Nov 2 2014 9:29 PM
Changing the work group name didn't help either.
I contacted BeoCare, but based on their initial rather naive responses I doubt that they will be of much help.
erichr
Posts 4
erichr replied on Wed, Dec 16 2015 9:38 AM
hi
i am having the same problem, did you finally find the solution?B&O engine and
i have had many visits from B&O engineer who now say its the internet connection and router. i am with sky when i contact them they are asking for the following
1. name for the service
2.protocol type for the port (TCP UDP or Both)
3.Port range (start and finish for the port)
no one is able to give me this info.
if your problem is fixed please help me also with the same
with thanks
Erich
Griebel
Posts 416
Griebel replied on Sun, Dec 20 2015 3:31 PM
The problem has indeed been fixed... but I unfortunately don't remember what was the solution. The problem was specific to one of my computers with Windows 8.
Page 1 of 1 (16 items) | RSS
