hi can anyone help recently acquired a beomaster 7000 / Beogram cd 7000 and need a remote what do I need
Sarah74: hi can anyone help recently acquired a beomaster 7000 / Beogram cd 7000 and need a remote what do I need
You dont need it, but you want this: http://archivedforum2.beoworld.org/forums/t/12508.aspx
http://tinyurl.com/qj9cjsf
Just use a Beolink 1000 or Beo4, 30 to 75 euro. Simple and efficient for that purpose.
Beolink 7000 is lots of lights and unhandy in daily use...
Brengen & Ophalen
Leslie:Just use a Beolink 1000 or Beo4, 30 to 75 euro. Simple and efficient for that purpose. Beolink 7000 is lots of lights and unhandy in daily use... Brengen & Ophalen
Leslie: Just use a Beolink 1000 or Beo4, 30 to 75 euro. Simple and efficient for that purpose. Beolink 7000 is lots of lights and unhandy in daily use...
I 100% agree Leslie and Beolink 7000 is not in any way magical!
Regards Graham
Yes but the Beolink 7000 opens a whole new facade of the 7000 and indeed 9500 systems. The programming feature allows true control over when the system switches on and off and when used in a link system gives you a virtual system in the link room with feedback on what is going on with the system.
For every day use, a Beolink 1000 is the remote of choice but a 7000 system without a Beolink 7000 is only half the system it can be.
Peter
I had a good - now long gone - friend once, who had the BL7000.
He also had a BS7000/AV9000 setup.
Man - we 'played' a lot with this thing then
Nice to be able to rewind a Tape preparing it for recording a CD/LP without interrupting what you just listen to....and such things - from the couch!
We used to program a cue of LP (one side), a CD, a Cassette und then Radio to hear in his workplace at the other end of the house (MCL2A-linked).
And he always called it 'his night remote'
A fantastic piece of electronics (especially at that time!!!), but not really needed today.
There are other ways to do things nowadays.
The BL7000 went, and the BL1000/the Beo4 stayed untill today - surely best way to control a B&O setup for most people.
