Hi guys,
When I had my BV8-40 in a ML set-up I had the opportunity to listen to an audio source whilst seing TV or playing video games. There was a specific Beo4 command that was used to activate this. Can anyone help me remember this command? I sure hope this also works with BV11 and ML/NL...
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
While watching your video source, select AV from your "LIST" followed by the audio source you want to listen to.
Ron
this feature doesn´t work with NL (for now; maybe a sw update would help?!?)
As I remembered this was also the way it used to work in the ML set-up. However I can confirm that it does not work in ML/NL. That is too bad
