Picture from one source and audio from another in a ML/NL set-up
This post has 5 Replies | 0 Followers
Beoberg
Odense, Denmark
Posts 315
Beoberg Posted: Sat, Nov 1 2014 10:40 PM
Hi guys,
When I had my BV8-40 in a ML set-up I had the opportunity to listen to an audio source whilst seing TV or playing video games. There was a specific Beo4 command that was used to activate this. Can anyone help me remember this command? I sure hope this also works with BV11 and ML/NL...
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Langleyav
Windsor UK
Posts 226
While watching your video source, select AV from your "LIST" followed by the audio source you want to listen to.
Ron
mjmedlo
Posts 922
mjmedlo replied on Sun, Nov 2 2014 2:06 PM
You'll have to select 'AV' the press the source of the audio you want to hear.
You'll lose video control but will have audio control.
I enjoy this feature for sports. Watching the he channel but listening to the terrestrial local radio broadcast.
IE. Press TV and choose the channel you want, then press 'list' until you see 'AV' press GO then press the source you want to hear audio from.
Good luck
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Nov 2 2014 3:30 PM
this feature doesn´t work with NL (for now; maybe a sw update would help?!?)
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Tue, Nov 4 2014 5:19 PM
As I remembered this was also the way it used to work in the ML set-up. However I can confirm that it does not work in ML/NL. That is too bad Sad
mjmedlo
Posts 922
mjmedlo replied on Tue, Nov 4 2014 5:21 PM
I have an NL/ML converter and that may be a factor?
As I think about it I usually use the audio source on my be 7. Haven't tried it on any of my NL televisions.
Page 1 of 1 (6 items) | RSS
