Hi all,
Does anyone have an idea how to open the base (charger) station of a beocom 2? Thought the battery was done for, so replaced it with a new set, but still it isn't charging, cleaned the contacts on both phone and charger to no avail and checked the voltage and current the base gives... 0, nothing, none what so ever, so guess I have to figure a way out to open the charger base... any takers? thanks.
Hi Patrick,
did you figure out of how to open the table charger? I have the same problem, just opened a threat for this issue
Regrads, Reinhard Paul
Reinhard Paul
BV11, BL8000, BL6000, BL11, Ouverture, BS5/BM5, Beocom 2
The plastic from the cover slowly softens and is very sticky. Awful to look at and
impossible to touch. Technically the cgarger works fine.
What special tool do I need? I shortly try a nutcracker :-)
Reinhard
The three screwdrivers did the job! Thank you for this helpful suggestion.
After having the baseplate off, the rest of the charger is easy to dismantle. You need 2 torn screwdrivers to get the heavy metal plate and the small base with the magnet and the DC pins out of the cover.
Reinhard Paul: The three screwdrivers did the job! Thank you for this helpful suggestion. After having the baseplate off, the rest of the charger is easy to dismantle. You need 2 torn screwdrivers to get the heavy metal plate and the small base with the magnet and the DC pins out of the cover. Reinhard
What will you use instead of the sticky cover that you have removed?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I used the original part from B&O. My local dealer ordered it for me. The electronics and all other parts fit smoothly only into the original cover.
Hi! My charger is also falling apart. Did you fix your? I think the material of the charger had only a 15 year life? Any replacement possible? Also the joystick fall apart, when I was trying to sell it!
Does anyone have the order number for the case?
