Spotify connect player for BS5
This post has 121 Replies | 8 Followers
beolion
Posts 485
beolion Posted: Wed, Nov 5 2014 6:19 PM
Hi
It does not looks like we are going to get Spotify Connect for BS5 ;-(
However, does anyone know that the cheapest system is that I can get to have Spotify Connect?
I then want to attach the system to the USB interface of my BS5, so I dont need a Spotify Connect speaker.
Just like PM or Airport Express with audio out, just also including Spotify Connect.
Thanks.
Millemissen
Flensborg, Denmark
Posts 14,680
You mean something like this:
https://www.gramofon.com/
http://www.techly.com.au/2014/07/06/gramofon-stream-spotify-speaker-cheap-wifi-router/
https://www.kickstarter.com/projects/fon/gramofon-modern-cloud-jukebox
Or just use the Essence-box Cool
beolion
Posts 485
beolion replied on Thu, Nov 6 2014 12:24 PM
Yes, that looks more like it. Thanks.
And to that price, one can still wonder why BS5 can not handle Spotify Connect.
Besides the license most likely.
gysse2004
Hellerup
Posts 192
Spotify Connect App for windows and Mac has been released in a Beta version, so it is definitely possible to run on a windows based machine. Big Smile
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
BeoMotion
Posts 384
BeoMotion replied on Sat, Nov 8 2014 10:42 AM
I think that since yesterday the CONNECT feature is officially integrated in the normal Spotify desktop client.
Since BM5 is Windows based I had success to install that via service menu and use it in background via A.AUX.
Seams to work well as far as I can see.
So this is a solution that will actually cost you nothing and sounds much better than the USB interface with external hardware. But remember that you are doing this on your own risk!
BR,
BeoMotion.
Millemissen
Flensborg, Denmark
Posts 14,680
@BeoMotion
Does that mean that you'll have to switch to A.AUX manually?
What does the screen show - i guess just A.AUX, or?
BeoMotion
Posts 384
BeoMotion replied on Sat, Nov 8 2014 11:22 AM
@MM
Yes, you have to switch to A.AUX manually and unfortunately you won't have any coverart since it has nothing to do with the BS5 software.
So it is similar to the "AirPlay mod" with shairport4W.
If you are using the CONNECT feature you are already holding the spotify app in your hand and won't really need the BS5 display.
Of course an Essence might be better for this purpose but if you already have a BS5 this is a good compromise. Of course the sound is also available through ML...
BR,
BeoMotion.
Millemissen
Flensborg, Denmark
Posts 14,680
What a waste of hardware and money to use a BS5 for that.
But if you already have that 'pretty thingy' hanging on the wall, I guess it is allright.
So thanks for the tip, anyway.
beolion
Posts 485
beolion replied on Sat, Nov 8 2014 2:15 PM
Hi
Great news, thanks. So you just need activate connect and and then a.aux and it plays?
What happens if you switch to radio? Will the connect on bm5 stop playing?
I am trying to understand how it works.
BeoMotion
Posts 384
I installed it on the following way:
- open service menu
- download Google Chrome since the IE seems to be too old for loading the Spotify HP
- download the Spotify windows client and log in with your account
- open the spotify preferences and activate MINIMIZED autostart, maximal playback quality and maybe disable HW acceleration (otherwise it may cause problems if shairport is also installed)
- CONNECT feature is automatically activated
-  leave the service menu
In fact it is running in background all the time and you will hear the music on all audio sources if you forgot to stop the CONNECT stream from your handheld. A.AUX is preferred since this is the only source where BS5 won't enter standby mode if no content was played during the last 10 minutes or so. (BS5 does not recognize that you play music through the "external" Spotify software...)
So it is not a very "clean and perfect" solution but seams to work if you can live with this compromise.
BR,
BeoMotion.
claudiu
copenhagen
Posts 193
It seems there are many of us who wish spotify connect to beosoun 5.
why not write an email to Bang Olufsen, to ask if this can not be so difficult now to introduce ??
lano
Posts 161
lano replied on Sun, Nov 9 2014 2:16 PM
BeoMotion:
- open service menu - download Google Chrome since the IE seems to be too old for loading the Spotify HP - download the Spotify windows client and log in with your account - open the spotify preferences and activate MINIMIZED autostart, maximal playback quality and maybe disable HW acceleration (otherwise it may cause problems if shairport is also installed) - CONNECT feature is automatically activated - leave the service menu
This worked fine for me also, nice to be able to browse music in Spotify and play it throughout the whole ML system.
With the Beolink app and MLGW I can also start A.Aux from every roomSmile
beolion
Posts 485
beolion replied on Mon, Nov 10 2014 8:22 PM
Hmm, could be nice if this Spotify for PC update is what B&O has been waiting for in order to enable Connect on BS5......
OK, I am dreamning, and I will try to enable this woraround soon.
Thanks for the tip Yes - thumbs up
Vintage_B&O
Germany
Posts 303
Great Solution - It works!!!
Mabye B&O will implement the feature in the next OS Release :-)
beolion
Posts 485
beolion replied on Sun, Nov 23 2014 7:57 PM
Just installed it, and it works perfect. Thanks a lot.
Now the BS5 has my own music collection in FLAC (CD), I have the radio (RADIO), I have the built in Spotify (using it for new and top albums only) (A.MEM), and with A.AUX I have Spotify connect, AirPlay (using a Behringer USB) and DNLA streaming (using Creation5).
Starting to be a pretty well featured media player for me at least.
All I need is a BS5 app to control all the stuff. = Nice to have.
In addition, and maybe as the only one here, I use the BM5 to my TV for slideshow of all our pictures.  It streams perfect and is very fast in 1080p resolution.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Nov 26 2014 7:21 PM
I wonder if there is some kind of workaround  to get Spotify Connect working on only a Beomaster 5. The BM 5 hasn't the A.Aux option or Spotify.
BeoMotion
Posts 384
BeoMotion replied on Fri, Nov 28 2014 10:49 AM
in theory that should work on a standalone BM5, too.
You could use the N.MUSIC source and press the stop button before you start the spotify connect stream.
The problem you might discover here is that your system will switch off automatically after some time since it thinks that nothing is played.
It could be possible that there is a value in the registry that can be changed to expand this auto-standby-timer.
There are a lot of changeable values and it might take some time to find the right one.
Only do this if you know what you are doing :-)
You could also try the source A-PC (or PC + P.MUTE depending on your RC firmware). I don't know if the standby timer gets activated on this source too...
BR,
BeoMotion.
lano
Posts 161
lano replied on Mon, Dec 1 2014 7:01 PM
Beobuddy:
It is possible, but you will have to change some registry values to make to BM5 software think you have a BS5 and set the BS5 software to start when you start the BM5. The you can activate a.aux with remote, MLGW or from a link room and use Spotify connect. Don't forget to turn up the volume on Spotify or else you will not hear any sound.
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Dec 13 2014 6:37 PM
I remember your suggestion some time ago. It made my Beo6 work with showing covers.
But it became unstable. And if I remember correctly, there needs to be a second screen if you trigger the BS5 functioning, didn't it?
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, May 9 2015 4:17 PM
Late to the party here...
I'm considering adding Spotify Connect to my BS5, but I have a question about turning on A.AUX.  The BS5 is "slaved" to a BS9000.  Therefore, when I press A.AUX, it activates the BS9000's aux input.  Is there a way to active A.AUX on the BS5 (without making it an audio master)?
Also, are we quite sure that B&O isn't going to do this on their own?  Has the BS5 been "end of lifed" now that the Moment has been out a while?
thanks in advance,
Stan
riverstyx
SouthWest UK
Posts 938
Hi Stan,
Hope this helps.
Martin.
How do operate BeoSound 5 in a system with another audio system using Beo4?
When BeoSound 5 is set up in a system with another audio system (that is when AUDIO MASTER is set to NO on BeoSound 5), you can activate following sources using your Beo4 remote control:
  • N.Music
  • Spotify (provided that you have an account)
  • A.AUX
How to active a source with Beo4 ...
Source
Beo4, type 162x
(with GO button)
Beo4, type 171x
(with navigation button)
N.Music
  • Press LIST until N.MUSIC
    is shown in the Beo4 display.
  • Press GO.
  • Press LIST until N.MUSIC is shown in the Beo4 display.
  • Press the centre button.
Spotify
  • Press GO.
  • Press 1.
  • Press 1.
  • Press Play.
A.AUX
  • Press GO.
  • Press 2.
  • Press 2.
  • Press Play.
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, May 11 2015 8:27 PM
Thank you for this.  I guess I can proceed with Spotify Connect install..
Stan
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Jun 9 2015 11:58 PM
I finally found the time to do this, and it didn't work Angry.
Spotify installs, but when it starts, it just disappears / crashes.  I believe it may have something to do with the fact that I use facebook athentication.  The first time Spotify runs, it asks for my credentials, and then it goes away.  When I try to use facebook authentication from the Spotify app, I get an error about not being able to reach the internet.  I tried using a deviceid / password, and that didn't work either.
Question 1:  Has anybody tried this recently?  I'm wondering if the BS5 is too ancient for the recent Spotify app.
Question 2:  Does anybody know how to move from Facebook authentication to non-Facebook authentication, or have you made this work using Facebook authentication?
I just had a thought that facebook authentication may work if I make Chrome my default browser...  I will need to give this a try...
Thanks in advance,
Stan
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Jun 10 2015 12:24 AM
Bad news:  I installed the Spotify app on another computer and logged in with my deviceid/password, and it works fine.  I think this should eliminate any network security, firewall issues (since the BS5 is on the same network).  However, logging in with the deviceid/password on the BS5 results in the Spotify app crashing :(.
I'm open to suggestions.
Stan
PS - there was a post missing that was in moderation where I explain that I've followed the instructions in this thread, but it's not working.  The post is now visible.
nico vercammen
Elversele, Belgium
Posts 174
I have exactly the same problem... No solution found yet ...
Nico
BeoMotion
Posts 384
BeoMotion replied on Tue, Jun 16 2015 11:00 PM
I just did a recovery on my BS/BM5 to find out whether I can reproduce this.
I downloaded the Spotify Windows installer on a normal PC and then transferred it via an USB stick to the BM5.
After launching the installer on BM5 spotify was downloaded and installed properly.
I was able to sign in with my credentials and everything worked like before. Including CONNECT.
Everything is stable and no crashes but I have to add that I never used the facebook login function. Maybe this is the reason?
BR,
BeoMotion.
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Jun 18 2015 9:02 PM
Did you install Chrome on your BS5?
That's the only difference I can think of that might matter.  There should be no difference in installing from a downloaded vs. ubs version of the install program.  A program is a program.  When I login using my deviceid and password, then facebook is not involved, yet still crashes.
I guess I will uninstall Chrome and try your installation approach.
Stan
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Jun 25 2015 11:02 PM
Tried uninstalling Chrome and installing Spotify via USB.  No luck Sad
Stan
Stan
Chicago-area USA
Posts 869
Stan
BeoMotion
Posts 384
BeoMotion replied on Fri, Jun 26 2015 9:16 AM
Stan:
Stan
That is strange.
I don't think that is has something to do with Chrome as I tried it with and without.
Maybe you want to try a recovery / factory reset of your BM5?
Before you do this, please make sure that your recovery is at least  version 5.00 or higher. Otherwise you will stuck on the old recovery version and no updates are possible.
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, Jun 26 2015 4:21 PM
How do you check the version of recovery?  I read about that problem so I have been treading very lightly because I do't want to be stuck on an old version.
Thanks,
Stan
BeoMotion
Posts 384
BeoMotion replied on Sat, Jun 27 2015 11:49 PM
You can see this within the "normal" service menu (not the windows desktop) under "product info".
BM5-OS-IMAGE should be the initial / recovery software your BM5 was shipped with. This one is reinstalled if you perform a factory reset / recovery.
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Jul 1 2015 12:16 AM
I successfully recovered my BS5, and then re-installed Spotify, and same result - Spotify crashes with no error shortly after logging in (I know it is logging in because when I supply a bogus userid/password, it fails to log in).
However, now that I had a safety net (because recovery worked), I started randomly clicking the .exe files in the Spotify install directory (Spotify.exe, SpotifyLauncher.exe, WebHelper.exe, etc.), and it started working.  I tried a number of times to find the reproduceable sequence of .exe clicks, and I couldn't get there except by just kind of clicking around until it worked.  Kind of a pain, but, what the heck, it works!!! Big Smile  (after I remembered to turn off audio master which is what it defaulted to after the recovery).  I think my BS5 reboots every Sunday night so I may have to repeat these steps weekly, but we'll see.
Thanks for the help BeoMotion (and the others earlier in this thread).
I was streaming from an iPhone via an Airport express, but the coverage was spotty in the back yard.  Hopefully, this will work better.
Stan
BeoMotion
Posts 384
Great that you got it working finally and letting us know your solution. :-)
Indeed a strange behavior and I really don't know why...
Stan:
Should be much better and much more responsive. The only back draw you have compared to a "real" CONNECT device like the A9 is that controlling the desktop client is only possible from within your local network and not via 3G. But even on a bad wifi network it works flawlessly.
BR,
BeoMotion.
lano
Posts 161
lano replied on Thu, Jul 2 2015 9:38 AM
When I tried Spotify connect the BS5 turn of after a while (30 min?). Is this due to no input on AUX or what it something else?
BeoMotion
Posts 384
BeoMotion replied on Thu, Jul 2 2015 10:18 AM
lano:
Okay, this is something I only had with a BeoMedia and the N.Music source where I pressed STOP to prevent hearing CD and spotify at the same time.
Can you confirm that you are using the A.AUX source on your BS/BM5 combo?
lano
Posts 161
lano replied on Thu, Jul 2 2015 10:39 AM
Yes, but when I think about it this was when I only had a BM5 with the BS5 s/w activated. I will try again now when I also have a BS5.
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Jul 2 2015 11:29 PM
lano:
I've been having the same issue today.  If I didn't have A.AUX enabled (N.Music, Go, 2), then it would play normal N.Music, no?  The BS5 shows a "Paused" screen.
My BS5 is NOT an audio master, but I don't know why this should matter (but sometimes it does).
I think it happened to me last night when listening in my back yard, but I blamed it on my wireless1 (and it could have been my wireless1 which is sometimes spotty).
Stan
lano
Posts 161
lano replied on Sat, Jul 4 2015 10:48 AM
I have now installed both Spotify and  Shairport4w on the BM5. Works really well, doesn't turn of and good sound quality.
I have a dedicated Spotify account on one of the iPads and the same account on the BM5 so easy to start and no conflict when away and using the private account.
Shairport4w makes it possible to stream AirPlay onto the ML/NL system (audiobooks etc).
MLGW and Beolink app gives me the possibility to start both Spotify and AirPlay in link rooms. I can also activate AUX on older Beolink passive and Beolab2000 via N.Music AUX in the MLGW. Everything controlled with an iPad😀
hackel
Posts 30
hackel replied on Sat, Jan 16 2016 10:48 AM
Thank you so much Beomotion !!
With your solution I can now control Spotify with my smartphone. Nothing else to do, I just have to Unblock the Exe file of Spotify (Property and Unblock), because nothing happen when I double clic on it.
It's working on any platform with Spotify (PC, Tablet, Smartphone).
And I don't need to re-program my Beo6, I already have the A.Aux at the second screen in all of my configuration.
It works perfectly and there is always the Beosound'Spotify choice but I don't think I'll use it now !!
Page 1 of 4 (122 items) 1 2 3 4 Next > | RSS
DigiCert Secured Site Seal
