Spotify connect player for BS5
This post has 121 Replies | 8 Followers
YoBe
Posts 2
YoBe replied on Fri, Jun 17 2016 7:28 PM
Great, it works! I think B&O should make this information part of its user guides - the spotify app on the BM 5 is a real drag without the "connect"-functionality, I was close to returning my center to the shop to have it sold, quite happy with it again :-) Thanks, Beomotion
Trolle
Posts 17
Trolle replied on Tue, Jan 3 2017 7:59 PM
I tried to follow your suggestion but when I try to connect to google to download Crome, internet explorer tells me it can't connect to the internet (despite I know it is connected to the internet)??
Any suggestions, hints or tips?
BR
Trolle
Posts 17
Trolle replied on Wed, Jan 4 2017 9:41 PM
Please se ignore this post. I managed to install it through a USB stick and it works well.
BR
Trolle
Posts 17
BR
Trolle
Posts 17
BR
Trolle
Posts 17
BR
Trolle
Posts 17
BR
garnaout
Posts 10
garnaout replied on Sat, Jan 28 2017 7:39 PM
I am dealing with this right now...  the B&O rep came to my house and confirmed that B&O will not update their support to the Spotify app and admitted about all the bugs they have.  For example, Spotify Playlists no longer work on the Beosound5.
I tried your approach but unfortunately, my BeoMaster isn't connecting to BeoConnect - need to debug that one first
Millemissen
Flensborg, Denmark
Posts 14,680
garnaout:
No need for 'debugging' there.
The BeoConnect is not supported in newer OS.
Map the BM5 drive on your PC/Mac instead and drag and drop your files from there.
Fl_ip
Posts 160
Fl_ip replied on Thu, Apr 6 2017 6:27 AM
We inform you hereby that the Spotify functionality in the near future will be removed from the BeoSound 5.
This change does not only affect Bang & Olufsen products, but also includes other brands that use the Spotify implementations. In addition, Spotify will also send a message to customers who use products to which the amendment refers.
Fl_ip
Posts 160
-Double
gysse2004
Hellerup
Posts 192
Again, where's the information coming from ?
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Fl_ip
Posts 160
Fl_ip replied on Thu, Apr 6 2017 8:53 AM
Bang & Olufsen Denmark
gysse2004
Hellerup
Posts 192
Will it get Deezer instead?
Peter
Fl_ip
Posts 160
Fl_ip replied on Thu, Apr 6 2017 8:59 AM
No, the solution is to connect an Behringer UCA 222 with an Chromecast Audio or an Essence
Duels
England
Posts 2,553
Duels replied on Thu, Apr 6 2017 3:30 PM
Fl_ip:
If this is true it is very disappointing for a product that was still being sold a couple of years ago.
gysse2004
Hellerup
Posts 192
Spoke to my B&O dealer today, and he confirmed that the Spotify support for BS5 is being discontinued.
sad news really. Makes the BS5 a limp product. Looks like the BS Moment is the next natural progression. Still like the look of the BS5 better.
Peter
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Thu, Apr 6 2017 6:33 PM
96 Normal 0 21 false false false DE X-NONE X-NONE
I bought mine end 2015 from a b&o dealer in vienna. So my beosound5 is not that old. It´s a big shame for b&o if there is no Spotify function in the software in the future. This was the reason for the purchase.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
gysse2004
Hellerup
Posts 192
Don't know if is any use, but I have disabled auto software updates on BS5. The unit still works, although slow...
Peter
Duels
England
Posts 2,553
Duels replied on Thu, Apr 6 2017 9:33 PM
I suspect lifestyle AV will have quite a few BS5s appearing on their site pretty soon. Whilst I bought my BS5 before the Spotify integration happened, I now listen to Spotify much more than my ripped CDs. To lose it after 3 or 4 years is a real backwards step.
So I now have to listen to Spotify through my a2 or a1 rather than BL18s. Not quite the same.
badgersurf
Posts 539
Lets just hope that the B&O push Deezer on to the BS5 (I know this is a very long shot), as I have a deezer account for my Moment already so would allow for some symmetry between the two products.
DocLeisure
Posts 101
exactly my thoughts... +1
Regards
DL
Duels
England
Posts 2,553
Duels replied on Fri, Apr 14 2017 2:00 PM
So my current status is that Spotify works other than playlists (which is a bit limiting). I can search as normal or play favourites/new releases. Going on playlists creates the " loading" then "no data found" message. And in fact I have to keep the pointer off playlists else we jam up.
Millemissen
Flensborg, Denmark
Posts 14,680
That is pretty much how the app in the tv's behave, too.
A pity for those, who are fond of using playlists.
But for me (and maybe for others) no big deal.
As long as I can search for what I need, I am fine....
....and they could keep it so on the tv's.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sat, Apr 15 2017 11:56 AM
@Duels- mine is behaving in a similar manner, although occasionally I can get in to the playlist mode. If I edit or create a new playlist on my iPhone, it does appear on the BS5, but only after a while.
Peter
Duels
England
Posts 2,553
Duels replied on Mon, Apr 24 2017 8:18 PM
Now Spotify is effectively gone. All searches seem to get the result that the "search matches nothing in the database" or words to that effect. New releases and favourites just show "no data found". Is that the end of Spotify on the BS5?
gysse2004
Hellerup
Posts 192
gysse2004 replied on Mon, Apr 24 2017 9:17 PM
Playlists and favourite is still working, and you can still add new playlists on iOS Spotify
Peter
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, Apr 24 2017 10:01 PM
I tried Spotify via BS5 this weekend, and I had to reboot my BS5.  Just going into Spotify mode did this Sad.  Last few times I tried, it sort of worked if I stayed out of playlists.  I guess it's probably Spotify changing their API all the time, and B&O not keeping up with an out of production product - the joys of "cloud based applications".
I guess I'm glad I have a $40 google chrome audio connected to by BS9000 (so I can control via phone / spotify connect) so I don't really need it, but I thought I'd do a sound quality comparison.  Obviously, the music play via the chrome audio sounded better than the BS5 rebooting Surprise
Stan
lano
Posts 161
lano replied on Tue, Apr 25 2017 5:21 AM
Mine BS5 has worked fine for a couple of weeks, but when I added some new playlists via iOS the playlist stopped working again (no data found after a long loading...). Yesterday the playlists started working again including the once I added. However, the "New releases" is now gone and they have always been working before?
Has there been any change on the Spotify side or is it something else that is hard to find the logic for (I have not changed anything else and not even used Spotify on iOS since I added the playlists)?
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Tue, Apr 25 2017 6:28 AM
Bad news: There was a newsletter last week or so to all dealers. Spotify will removed from all b&o products till may 2017. (i think the spotify connect feature will be remain because b&o recommends to buy a beosound mk2 essence to hook up to the beosound5 with a usb-Behringer UCA222. (info from beo”care”)
Duels
England
Posts 2,553
Duels replied on Tue, Apr 25 2017 9:52 AM
beoandy:
On another thread there was mention of the hub from the new Shape being available in a couple of months as a new essence alternative. Might be better to wait for that.
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Apr 25 2017 4:31 PM
beoandy:
I agree that if it doesn't work, they should fix it.  I didn't expect the "fix" to be remove it, but I guess I can understand there are probably support issues with the BS5 and the old Windows OS that it runs.
Spotify connect *must* remain as this is the main reason I bought my Essence.
Stan
lano
Posts 161
lano replied on Tue, Apr 25 2017 7:49 PM
I really hope that Spotify remains on the BS5, else it will not be of much use.
What point is it to connect a BS Essenes or Core to the BS5? Don't you just end up with dibble controls for volume and source selection? For me it would be better then to skip the BS5, but I do really like the look and feel of it.Sad
beolion
Posts 485
beolion replied on Wed, Apr 26 2017 12:22 PM
I don't really understand why. I adjusted the playlists the other day, and then it did not work on BS5 anymore.
Removing account and adding it again fixed it. Very strange behaviour.
nico vercammen
Elversele, Belgium
Posts 174
I do not understand their communication ....
I reported the spotify problem @beocare   already several times and every time I receive the answer that their developers will investigate the problem.
Never received an answer that it will not be supported anymore ... (even last week..)
I've sent emails to Spotify support also, but no real answer either ... (they will investigate ...)
I do not understand the relationship between spotify and B&O... If you make an (expensive)  product you need a bullet proof  contract with  the other party for several years I think.. ? at least 10 years ?
The BS5/BM5 is maybe not the newest system by B&O but it still looks great (even it works with XP embedded it is stable now).
My feeling is the BS5/BM5 has still better looks than the Moment.....( but that is maybe personal)
Also we should not care what system it is running on, that's B&O's problem.... it should just work ..
Also I have problems to be pushed by vendors to use  my smartphone/tablet   as a "music system". This is not the same for me than a dedicated system.
And if you need to change to the Moment or to a Essence .. how long will it be supported by the other vendors like Deezer, Spotify etc ... there is no standard for streaming ...
This is changing the lifte time for a product drastically...  We are now even in a more "throw it away world" than before.
My BS9000 is still working perfectly, I have 2 beograms, they still work perfect, even they are more than 30 years old. Because they are based on standards.
What could we do with a today's product in 20 years from now ... nothing i guess..... Ok technology is changing quickly, but after a certain period it should stabalize and vendors should agree on a standard.
Look at the audio file format type.. we have .. mp3, flac, wav  etc etc etc ... We' ve seen lots of audio file formats but still no consensus between vendors...
Finally they seem to agree on a charging connector  standard .;-) .. maybe something similar has to be done for streaming ... technically I beieive it should be possible. I'm a techie and i do not see any problem it should be possible to develop a standard for making a connector for streaming services. It could be like the 7 layer OSI model  for networks ... a standard for streaming music :-)
nico
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Apr 26 2017 8:11 PM
This is unfortunately the way of the "cloud".  Any streaming/cloud product now depends on an external service on which you have no control.  Maybe enough people will get screwed over enough, and people will force laws to enforce a minimum service life, but I'm not holding my breath.  Even with a 7 layer OSI standard, you'd still need "metadata" exchange frameworks (for finding songs, etc.), and in today's fast moving world "ain't nobody got time for that".
Duels
England
Posts 2,553
Duels replied on Fri, Apr 28 2017 9:43 AM
Now I just get the message internet connection not available when I try to engage Spotify. Is this how anyone else's BS5 is working?
gysse2004
Hellerup
Posts 192
gysse2004 replied on Fri, Apr 28 2017 10:06 AM
No problem here, still up and running
Peter
Nidi
Posts 46
Nidi replied on Fri, Apr 28 2017 12:14 PM
Today again work Spotify fine....until yesterday no new releases and top albums.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Fri, Apr 28 2017 12:53 PM
Mine is working, including new releases, playlist and favourite.
Peter
Page 2 of 4 (122 items) < Previous 1 2 3 4 Next > | RSS
