Beoplay a9 as center speaker, did you try it ?
olvisab
Posts 1,391
olvisab Posted: Thu, Nov 13 2014 2:41 PM
Hi
Still searching for the most suitable center speaker for my needs :
- must be wall mounted and shorter than a bl7.2
- should look good between my bl5 on the floor and bl5000 wall mounted on each side of the screen
- must be as good as the bl7.2
I thought about the 7.1 but I wonder if an a9 won't be a good alternative because of its look ( rounded form will cut the square form of the bl5000), power and quality of sound, differents frets available, airplay functionality (bluetooth for the new one).
Connect it is not a problem with or without a bv.
What do you thing about this possibility ?
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
elephant
AU
Posts 8,219
elephant replied on Thu, Nov 13 2014 9:23 PM
Remind us of the type of TV ...
If a BV then I suspect the A9 would not be on the customisation menu and you would need Geoff Martin's advice on what might approximate ...
On looks alone I would say it would be an inspired choice !
BeoNut since '75
olvisab
Posts 1,391
olvisab replied on Thu, Nov 13 2014 9:57 PM
elephant:
On looks alone I would say it would be an inspired choice ! The Essence of B&O is discretion in design and life
Hi
You are right. If I use it with a bv (should be the case for the audio part only with a bv hidden), I don't know which b&o speaker I should select from the list.
Hope Geoff will see this thread and take mn to answer (mn not seconds because is answer are usually so precise and detailed).
I don't know if it is inspired or not, but It came to my mind like an evidence when I look at my actual setup.
Chris Townsend
Qatar
Posts 3,531
At low volumes the A9 can be quite boomy, and until the A2 I simply turned up my mini iPad when listening to a talk show etc.
2 A9's as supplementary left and right speakers would be a laugh, but I'm not convinced as a centre.
olvisab
Posts 1,391
olvisab replied on Thu, Nov 13 2014 11:06 PM
Chris Townsend:
2 A9's as supplementary left and right speakers would be a laugh, but I'm not convinced as a centre. Beovision 7-55 Mk2, Beovision 8-32, Avant RF 28, Beolab 8000, Beoplay A9, Beoplay 2, Beocom 2, Beotime, H6, Form 2.
You have a bv 7, you have an a9, after the A 2, it´s time to a new experiment. Big Smile
olvisab
Posts 1,391
olvisab replied on Sun, Nov 16 2014 8:27 AM
As nobody can make a test and geoff seems to be too busy unfortunately, I will buy one and make the test myself, as usual.
The new one will have deezer and spotify built in but all I need is a center speaker after all.
Page 1 of 1 (6 items) | RSS
