Masterlink Beocenter 6 to Beolab 2000 connection
This post has 3 Replies | 0 Followers
Simonbeo
Posts 1,451
Simonbeo Posted: Sat, Nov 15 2014 5:02 PM
I'm planning to feed a Beolab 2000 from the Beocenter 6 in the next room (landing) and wondering if anything more than a masterlink cable is required. The diagrams from B&O all appear to have a connector box half way. Is this needed for some reason?
thanks
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Nov 15 2014 9:15 PM
The junction box is only needed if you have to cut the cable to pass it through a hole in a wall for example. If you can use a straight length of Masterlink cable with a plug at each end you don't need anything else.
Opman
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Nov 15 2014 9:31 PM
Thanks Opman. Looks like there's no ML cable equivalent of Sounds Heavenly detachable ended scart plug?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Nov 15 2014 9:47 PM
It is possible to crimp a Masterlink plug onto Masterlink cable but you need a special crimping tool. The easiest way to join the cable once cut is by using the junction box. Its relatively cheap and not too difficult to DIY.
Opman
Page 1 of 1 (4 items) | RSS
