I'm planning to feed a Beolab 2000 from the Beocenter 6 in the next room (landing) and wondering if anything more than a masterlink cable is required. The diagrams from B&O all appear to have a connector box half way. Is this needed for some reason?
thanks
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
The junction box is only needed if you have to cut the cable to pass it through a hole in a wall for example. If you can use a straight length of Masterlink cable with a plug at each end you don't need anything else.
Opman
Thanks Opman. Looks like there's no ML cable equivalent of Sounds Heavenly detachable ended scart plug?
It is possible to crimp a Masterlink plug onto Masterlink cable but you need a special crimping tool. The easiest way to join the cable once cut is by using the junction box. Its relatively cheap and not too difficult to DIY.
