LC1 dismantling
This post has 17 Replies | 1 Follower
jvezina
Montreal, Canada
Posts 200
jvezina Posted: Tue, Nov 18 2014 4:00 PM
Good evening,
I want to dismantle one of my LC1 dimmers in order to replace capacitors. I saw that Leslie has repaired one recently. What is the "trick" to open the housing without damaging it?
Thanks in advance,
Best regards,
Jean
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 19 2014 8:54 PM
Just 4 screws at the bottom Jean. The rest is quite obvious I guess. Protect your bling bling toppanel with tape (scratches). Good luck!
Brengen & Ophalen
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Nov 19 2014 9:05 PM
Leslie:
If I remember correct, then the original screws actually was "one way" screws.. They could only be turned clock-wise.. When trying to un-screw them, the screwdriver could not get a grip.
I had some difficulty with one I had a looong time ago, but I managed to get the screws out by using a very sharp screw-driver, it took some time as I remember :)
Replaced the one-way screws with normal one's when assembling again :)
/Weebyx
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 19 2014 9:10 PM
Can't remember I've seen one-way screws. For what reason?
Brengen & Ophalen
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Nov 19 2014 10:03 PM
Leslie:
"Don't tamper with it" reason I guess :)
I am 98.99% sure mine had these screws, But I can be 1,01 % wrong off course... :)
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 19 2014 10:07 PM
I have 3 or 4 LC1's here so I can check :-)
Brengen & Ophalen
jvezina
Montreal, Canada
Posts 200
Good evening,
Thank you very much for your replies and sorry for the late reply. In fact, I had already removed the screws and tested one capacitor with an ESR meter. It is bad without any doubt.
The problem is to remove the small board. It is retained by two metallic plates. Can it be just pulled out by prying it or a more complicated procedure is required to remove it ? I have included two pictures. The first is my own LC1 showing the two capacitors I want to replace and the second is Leslie's repaired one.
Thanks in advance,
Jean
  • Filed under:
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 25 2014 9:12 PM
I think I just cut the leads of the cap and soldered the new one on top. So I did not removed the board.
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 25 2014 9:15 PM
Leslie:
Just 2 (not 4) plain "2-way" screws to remove the bottomplate.
Brengen & Ophalen
Steffen
Denmark
Posts 1,408
Steffen replied on Tue, Nov 25 2014 10:46 PM
-some of them has these screws. (Only one in this one):
jvezina
Montreal, Canada
Posts 200
jvezina replied on Wed, Nov 26 2014 3:53 AM
Leslie:
Thanks!
I will then try that first and leave the red capacitor to see if the problem is solved (light turns off after a few seconds, then flashes).
I searched the archived forum and found only that less than satisfying solution to remove the board:
http://archivedarchivedforum2.beoworld.org/forums/p/29305/231828.aspx#231828
Thanks,
Jean
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Nov 26 2014 5:25 AM
Steffen:
Type 2111 for DK not allowed to open it
Type 2110 for NL allowed to open it
Just a wild guess :-)
Brengen & Ophalen
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Nov 26 2014 6:28 PM
Leslie:
Steffen:
I knew it !!  :)
My memory is still working, it has been 24 years or so, since I had one of these :)
/Weebyx
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Nov 26 2014 8:30 PM
I got a Little curious about those screws - so I just 'Googled' them...
They're called "Tri-wing". Those can also be found in Nintendo etc. They probably don't want 'anybody' to open their devices. As far as I can see, they are not 'one-way' -but they require special bits or screwdrivers.
Hard to find in 'physical' stores, but you can buy them in many web-stores.
-and there are even guides on Youtube for those who don't want to buy special tools to get these screws out...Laughing <img src=" />
https://www.youtube.com/watch?v=A9emKL0YgIw
Radiomekaniker
Posts 49
Hi I little trick that I have used to get safety screws loss (in plastic) it to use a soldering iron to heat the screw a bit then it can be grabbed by a pair of pliers/screwdriver.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Nov 27 2014 9:42 AM
Steffen:
I guess you are right about them not being "one-way", I remember that I used a flathead screwdriver to get it undone with, took some time, but did it :)
/Weebyx
jvezina
Montreal, Canada
Posts 200
jvezina replied on Wed, Dec 10 2014 10:34 PM
Good evening,
By the way, does a schematic diagram of the LC1 was ever published by B&O? I think there is no proper service manual available.
Thanks in advance,
Jean
jvezina
Montreal, Canada
Posts 200
Hi everybody,
Just to say that I repaired my LC1 successfully. Replacing only the axial capacitor that measured bad was sufficient to bring it back in operation.
I did exactly what Leslie did: soldering the new capacitor on the pins of the removed bad one. I did some research about opening the housing and it is not possible without forcing the top and the bottom parts with a screwdriver.
Best regards,
Jean
Page 1 of 1 (18 items) | RSS
