Beovision 11 Saying not connected to Internet - When it is
Debs
Posts 2
Debs Posted: Sun, Nov 23 2014 12:21 AM
hi, has anyone had trouble with their Beovision 11 saying no network connection available but when I look at Network settings it say it is connected?  I can't play any streaming or Apple TV loading, I have BT infinity with home hub 5.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Nov 23 2014 12:33 AM
Have you tried rebooting your router? Often when I have a device that thinks its connected but can't actually connect that fixes it.
Jeff
MartinW
Posts 389
MartinW replied on Sun, Nov 23 2014 11:11 AM
This is a very common problem with the BT router where it does not renew the 'lease' to the IP address - meaning the device will show as connected to the network but it will not work.
As Jeff said, rebooting your router will fix the problem temporarily, for a more permanent solution you should change your router to something like a Linksys/Cisco.
I was having to reboot my BT router everyday, I got a Cisco router and now i reboot it about once every few months.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Nov 23 2014 11:44 AM
I have a Linksys dual band route and like Martin and I only am forced to reboot every 4-5 months. Sounds like the BT routers are no prize. Then again I've had similar issues with the cheaper Linksys and Belden routers, this seems to be an area where money does buy a better product.
Jeff
Debs
Posts 2
Debs replied on Sun, Nov 23 2014 1:10 PM
HI, thanks, have tried and not successful so far.  I do suspect it is the BT Router,  Thanks.
vlohjr1
Posts 553
vlohjr1 replied on Sun, Nov 23 2014 5:16 PM
Debs
Exactly the same here cisco totally sorted it out I have ea6700 but the newer ones should work equally
Regards
Vince
SHEFFIELD
Posts 262
SHEFFIELD replied on Sun, Nov 23 2014 5:26 PM
When it says connected, go to edit and insert router password again and all will be okay...
Page 1 of 1 (7 items) | RSS
