hi, has anyone had trouble with their Beovision 11 saying no network connection available but when I look at Network settings it say it is connected? I can't play any streaming or Apple TV loading, I have BT infinity with home hub 5.
Have you tried rebooting your router? Often when I have a device that thinks its connected but can't actually connect that fixes it.
Jeff
I have a Linksys dual band route and like Martin and I only am forced to reboot every 4-5 months. Sounds like the BT routers are no prize. Then again I've had similar issues with the cheaper Linksys and Belden routers, this seems to be an area where money does buy a better product.
HI, thanks, have tried and not successful so far. I do suspect it is the BT Router, Thanks.
When it says connected, go to edit and insert router password again and all will be okay...
