Hi Guys,
Has anybody got the HiFi News test LP and if so how does your Beogram perform on the 300Hz trackability tests?
Regards,
Lee
Anybody?
I have seen the LP for sale but haven't ordered one. I wonder how it compares to other test records. It costs around $50 USD here in the United States.
-sonavor
It seems to be quite comprehensive for testing your record player.
The problem I have got is when I play the tracks to test Bias settings. There are 4 tracks that play a continuous 300Hz tone at varying levels (starting at 14db and going up to 18db equal in the L+R channels) its designed to test how well your stylus tracks the grooves. I get audible distortion at all levels on my Beogram 5005 with Axel retipped mmc2. In the notes it says that if you get buzzing or distortion in either channel adjust your anti-skate settings til' the tone is clear, but obviously the 5005 is tangential and so has no anti-skate settings.
I've tried upping the tracking force (tested with a stylus force meter) from 1.2g to 1.4g and it is better but still not right. If I increase the stylus force to 1.7g it manages the 14db tone but that seems like far too much pressure... The mmc2 (line contact, sapphire cantilever) is fresh from Axel this week, I sent the last one back a couple of weeks ago due to a similar issue.
Deleted duplicate post
Interesting results. You should ask Frede at Classic Audio about the test. He does a lot of turntable testing.
You wouldn't happen to have an email address for him would you? I've tried google but can't find it.
I did find his site but the contact page wont allow me to send a message.
Deleted Duplicate - Don't know why it keeps double posting :-(
@Lee
Probably you are too eager pusshing the button
Are you using this url?
http://www.classic-audio.dk/content/classic.php?page=form
Yes, although I think I have cracked it. I wasn't putting the correct letter in the final box.
I have a special B&O test record double album.
Just naming what's on the first record..
Reference level 1000Hz
Balance test
Phase test
Channel identification
Frequency response left channel
Frequency response right channel
Channel separation
Rumble test
Pink noise broadband
White noise broadband
Wow and Flutter test 3150Hz
Orange album shown on this thread
http://archivedforum2.beoworld.org/forums/p/3906/35445.aspx#35445
Brengen & Ophalen
I'd love to find a copy of that Leslie, looks like just the thing I need.
Lee: I'd love to find a copy of that Leslie, looks like just the thing I need.
I bought a couple of test vinyls via eBay which seem to work really well. One with test frequencies to test your hearing range and all of the other features the one Leslie mentioned, and another with 4 different instruments (organ, brass, percussion and strings) which really test trackability on difficult musical pieces/volumes and frequencies.
Just do a search on eBay for test LP or test vinyl.
This for example: http://www.ebay.co.uk/itm/Hi-Fi-News-Test-LP-/291279920094?pt=Turntable_Parts_Accessories&hash=item43d1a2dbde
Dave.
Dave thats the one I have and the one I'm having problems with. Is that the one you've got? (HiFi News Test LP)
Lee: Dave thats the one I have and the one I'm having problems with. Is that the one you've got? (HiFi News Test LP) Lee
No, sorry, it was just an example of what you can find.
I have a CD-4 4ch/2ch test record by Louis Dorren. But the other is a Shure TTR 101 test record called 'An Audio Obstacle Course'.
Dave, can this 4CD test record be used for my BM6000 quad with the BG6000 recordplayer?
Leslie: Dave, can this 4CD test record be used for my BM6000 quad with the BG6000 recordplayer?
Absolutely as the BG6000 has the CD-4 decoder as standard.
From the sleeve, it does:
SIDE 1:
White noise separation and adjustment
Channel identity test for quad and 2 ch
System balance test
Stepped frequency response 30Hz - 15kHz - no CD-4 carrier
Explanation of frequency sweeps on tests
LF and LR frequency sweep
RF and RR frequency sweep
Cartridge separation check, no CD-4 carrier
CD-4 auto switching function test
SIDE 2:
Intro and channel identification, separation adjustment and then a series of musical tracks.
A code on the sleeve says 'SB4X 002'. It's from 1975 by Sutton-Miller Ltd.
Title: CD-4, Quadradisc. 4-channel/2-channel Test record.
By: Louis Dorren and James Gabbert.
I have got the Shure audio obstacle course LP as well. How do your cartridges perform on the bass drum test?
Leslie,
about 4 hours ago I replied to this with a long post containing all of the record and track details. I had a pop-up saying it was being moderated! It's vanished into the ether again! Hopefully it will reappear.
Thanks Dave, still curious how quad sounds like on my completely overhauled BM6000 system. Got it back few weeks ago from Olly (Step1) and it looks fantastic what he did with this horrible machine.
Tomorrow business trip to Singapore and Indonesia and when I'm back I will start setting up my quad system. Can't wait....
Well I've been doing a lot of tinkering and had some correspondence with Frede at Classic Audio, and I've settled on a tracking force of 1.8g, which Frede assures me isn't too high.
I'm beginning to think the short and lightweight tone-arm on the 5005 is the real problem, its got no damping whatsoever. Hopefully going to get a 6006 or a 6002 at the weekend so I'll see how it performs on those.
-Deleted Duplicate Post -
My god Lee, you did it again double posting. :-) You should wait at least one minute after you push the post button.
Hahaha Leslie get off here and enjoy your holiday ;-)
I'm blaming this stupid laptop ;-) really think you should be able to remove your own posts - moderators are you listening? :-)
Just put in a smiley - then we know why
Can't be done using a smartphone MM :-(
