Listening presets with a bv 7 40 mk6
olvisab
Posts 1,391
olvisab Posted: Tue, Nov 25 2014 7:44 PM
Hi
I just discovered the Adaptiv sound technology on the bv 7 40 mk6 and the Listening preset functions.
This last function interests me a lot.
Can I select a listening preset easily from the MLGW ?
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
beojeff
USA
Posts 2,012
beojeff replied on Tue, Nov 25 2014 9:54 PM
Greetings fellow MLGW user!
I tried inspecting the AST preset buttons in the Beo5/Beo6 programming software. However, it did not show what the IR codes are for the presets.Very odd. I thought that if we could see what the IR codes are, it would be easy to establish control from the MLGW.
olvisab
Posts 1,391
olvisab replied on Tue, Nov 25 2014 10:47 PM
beojeff:
Hi beojeff,
Still available for talking about this great tool,thanks.
It is possible to use the listening presets by selecting each steps from the main menu to the final presets. A lot of steps are needed but it should work. The exit button should be used in order to select the good preset.
I am afraid there is no other way.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Nov 26 2014 9:03 PM
It occurred to me what I was doing wrong: In order to see the AST codes in the Beo5/Beo6 emulator, you must first select a video source in the emulator.
The IR command for AST is: 0:000:TV:PANEL_OFF
The IR command for the subsequent Preset 1 is:
0:000:TV:SOUND
0:000:TV:FUNCTION_1
After a time-out moment, the emulator then shows again: 0:000:TV:PANEL_OFF
The other presets use the corresponding FUNCTION_2, FUNCTION_3, etc.
The Cinema preset uses FUNCTION_7
olvisab
Posts 1,391
olvisab replied on Wed, Nov 26 2014 9:32 PM
beojeff:
0:000:TV:SOUND
0:000:TV:FUNCTION_1
Could you please explain or translate this in mlgw commands ?
There are function commands in the list of commands available but I don't know when it can be used
beojeff
USA
Posts 2,012
beojeff replied on Fri, Nov 28 2014 1:37 PM
I'm not sure about the MLGW commands, but I just thought I'd share with you the emulation capture of what the B&O IR commands are. For example: SOUND or FUNCTION_1 -- which can be found on the B&O remote controls. At least this lets you know what the IR commands are that the Beo6 uses to send controls for the AST. You might want to take a look at the BeoLink Gateway Protocol Specification that can be downloaded under the Home Integration section of the Bang & Olufsen website.
olvisab
Posts 1,391
olvisab replied on Fri, Nov 28 2014 2:31 PM
beojeff:
I had an idea how I can use these precious information, I just needed a confirmation from you.
I will make some tests and let you know if it works for me.
Thanks again
Page 1 of 1 (7 items) | RSS
