4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Greetings fellow MLGW user!
I tried inspecting the AST preset buttons in the Beo5/Beo6 programming software. However, it did not show what the IR codes are for the presets.Very odd. I thought that if we could see what the IR codes are, it would be easy to establish control from the MLGW.
beojeff:Greetings fellow MLGW user! I tried inspecting the AST preset buttons in the Beo5/Beo6 programming software. However, it did not show what the IR codes are for the presets.Very odd. I thought that if we could see what the IR codes are, it would be easy to establish control from the MLGW.
It occurred to me what I was doing wrong: In order to see the AST codes in the Beo5/Beo6 emulator, you must first select a video source in the emulator.
The IR command for AST is: 0:000:TV:PANEL_OFF
The IR command for the subsequent Preset 1 is:
0:000:TV:SOUND
0:000:TV:FUNCTION_1
After a time-out moment, the emulator then shows again: 0:000:TV:PANEL_OFF
The other presets use the corresponding FUNCTION_2, FUNCTION_3, etc.
The Cinema preset uses FUNCTION_7
beojeff:It occurred to me what I was doing wrong: In order to see the AST codes in the Beo5/Beo6 emulator, you must first select a video source in the emulator. The IR command for AST is: 0:000:TV:PANEL_OFF The IR command for the subsequent Preset 1 is: 0:000:TV:SOUND 0:000:TV:FUNCTION_1 After a time-out moment, the emulator then shows again: 0:000:TV:PANEL_OFF The other presets use the corresponding FUNCTION_2, FUNCTION_3, etc. The Cinema preset uses FUNCTION_7
I'm not sure about the MLGW commands, but I just thought I'd share with you the emulation capture of what the B&O IR commands are. For example: SOUND or FUNCTION_1 -- which can be found on the B&O remote controls. At least this lets you know what the IR commands are that the Beo6 uses to send controls for the AST. You might want to take a look at the BeoLink Gateway Protocol Specification that can be downloaded under the Home Integration section of the Bang & Olufsen website.
beojeff:I'm not sure about the MLGW commands, but I just thought I'd share with you the emulation capture of what the B&O IR commands are. For example: SOUND or FUNCTION_1 -- which can be found on the B&O remote controls. At least this lets you know what the IR commands are that the Beo6 uses to send controls for the AST. You might want to take a look at the BeoLink Gateway Protocol Specification that can be downloaded under the Home Integration section of the Bang & Olufsen website.
