Beomaster 5 broken - service supposes the mainboard
This post has 17 Replies | 4 Followers
vogelr
Posts 4
vogelr Posted: Sat, Dec 6 2014 8:02 PM
a few weeks ago my beosound 5 didn't work anymore…
cold boot, power of/on nothing helped. I heard the HDD sound, so I suppose, power supply and HD should be ok. I supposed a windows or system update as cause, but I should be proofed wrong…
Last week I got the news from the B&O shop: their contractor supposes, the mainboard should be replaced: 800 EUR. And another 500 EUR to clone the Harddisk. 1300 EUR ????
This is a PC! Bombaster is a PC. Nothing else. No Raid-HD, plain PC. ????
Do I really have to pay 1300 EUR for the replacement of the mainboard and a new installed system on the HDD?
I'm shocked & frustrated. There is no magic in PC repair: a regular mainboard is 50+ EUR and installing a new operating system is 2h work for a newbie. (I'm building my PC's from parts for 20 years. This makes it hard to understand)
My Question:
Where can I get the mainboard?
Who can tell me the type of the mainboard or where I can get one and who can tell me how to install the operating system (if this windows system needs to be re-installed, once the mainboard has been changed)
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
Is your problem the same as this one?
http://archivedarchivedforum2.beoworld.org/forums/t/30233.aspx
It's some time ago, but it does look as if B&O did accept that they had a batch of faulty motherboards.
Graham
vogelr
Posts 4
vogelr replied on Sat, Dec 6 2014 8:40 PM
I bought the BS5 in 2009 and the replaced the system a few months after I bought it.
Now, 5 years later, It is down again.
So, who can help?
Do I have to pay 800 EUR for an average processor mainboard which was designed prior to 2009?
Pls, no!
pf85
Posts 284
pf85 replied on Sat, Dec 6 2014 10:16 PM
I had an early BM5 2009 with mb replacement in 2009 and 2010. The mb failed again in 2014 and was paid as policy per request of the dealer. I only paid labor. The motherboard is an achilles heel and B&O know it. In your shoes, I would request my dealer to seek a policy solution by the manufacturer.
Vintage_B&O
Germany
Posts 303
You can get a Motherboard at eBay and replace it. I also bought 3 motherboards at ebay an repaired the beosound 5.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Without the proper (service)tools you can't programm the serialnumber into the Bios.. Without serial there will be no updates.
badgersurf
Posts 539
The motherboard on my BM5 went I was told it was out of warranty, and it would be £400 to replace. Still waiting to see if it could have a future within a NL network without a BS5 before I get it fixed!
Vintage_B&O
Germany
Posts 303
you can force the firmwareupdate in the system menu. so that is no problem.
the motherboard costs 25 euro at ebay.
vogelr
Posts 4
vogelr replied on Sat, Dec 13 2014 9:46 AM
When searching for "Mainboard" and "Beomaster 5", I didn't find any offers.
What is the trick?
And, do I have to do anything with the HDD or the system on the HDD, after the Mainboard is changed?
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Dec 13 2014 6:32 PM
MircoHH:
Without matching numbers from hdd and Bios it wasn't possible. Prograaming the serial into the Bios isn't possible (not with the standard Bios programmer from Epia.
Do you have the Original BIOS startup screen? Using a genuine Epia board, the B&O isn't showed.
StUrrock
Posts 995
StUrrock replied on Tue, Jan 27 2015 9:03 PM
Beobuddy:
it's only a USB stick?
talisman
Sweden
Posts 54
talisman replied on Tue, Jan 27 2015 9:25 PM
Yes the service soft for Beomaster 5, is fitted on a USB stick. !
richtoy
Posts 18
richtoy replied on Tue, Jan 27 2015 9:45 PM
And dealers wonder why they have few new customers... It is just sheer greed...
frog
Camberley UK
Posts 624
frog replied on Thu, Feb 22 2018 11:57 AM
Has anyone worked out how to replace the motherboard and get the beomaster working again?
Is it essential to get the serial number onto the motherboard or are just updates not supported as mentioned above?
maki82
Posts 23
maki82 replied on Thu, Oct 8 2020 9:57 PM
Does somebody have any informations which motherboard is compatibel, how to change the motherboard and to bring the whole system to work again??
King regards
Mario
maki82
Posts 23
King regards
Mario
TWG
Posts 1,672
TWG replied on Sat, Oct 10 2020 9:06 AM
please have a look here:
https://archivedforum2.beoworld.org/forums/p/14541/297790.aspx
maki82
Posts 23
maki82 replied on Thu, Oct 15 2020 12:59 PM
Thank you ... hopping this is going to help me :)
Page 1 of 1 (18 items) | RSS
