My BeoSound 3200 suddenly does not play cd's
Bloomfield
Posts 4
Bloomfield Posted: Sat, Dec 13 2014 2:49 PM
nor does it react to any of the buttons, either on the remote control or the stereo itself - except for opening the door and allowing changing of cd's. Otherwise, it does nothing else. So, electricity is not the  problem. What is?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Dec 13 2014 3:00 PM
Odd...  especially if the buttons don't work either.
Have you just disconnected it from a MasterLink system, or was it working perfectly and now just frozen up?
Lee
Bloomfield
Posts 4
Hmmm, I don't know what the MasterLink system is. It had been working perfectly; however lately I have not used it that often, and yes it does seem to be frozen up except for being able to open and close the door. That's the only thing that works.
From another website, I read the advise to unplug the system for a couple of hours and then before reconnecting it, I should push the on/off button several times. Sounds a little like sorcery and not science but that's what I'm right in the middle of trying.
Kim
solderon29
U.K.West Midlands
Posts 764
I think these units are pin protected?The doors/clamper will work,but nothing else,after a power interuption.
Check your owner guide for the pin and instructions on how to enter?
Nick
Bloomfield
Posts 4
Thanks, Nick. Yes, I have tried that: i.e, consulted my owner's manual and tried to enter my PIN. But ALL buttons except for the 'load' button are frozen and don't work.
I am planning to go to the electronics store where I bought the system (7 years ago!) and ask them what is to be done because there seem to be no other 'homemade' solutions to try.
But thanks again for your suggestion!
Kim
TWG
Posts 1,672
TWG replied on Mon, Dec 15 2014 7:16 PM
- Perhaps a defective CPU board. This was the reason of my dead Beosound 3000 a few years ago
- Some kind of child protection / door lock? As far as I know the Beosound 3200 has a mode to be safe from childrens curious little fingers :)
see this thread: http://archivedforum2.beoworld.org/forums/p/9149/80509.aspx#80509
Bloomfield
Posts 4
Hi TWG,
thanks for your suggestion, but I think my system is too old to follow the instructions you gave the link to, as my remote and the console keyboard have no 'shift' key.
I think I have to get in touch with B&O themselves about the problem. But thanks much for the time you took to write me. :-)
Kim
Page 1 of 1 (7 items) | RSS
