Mystery spring beogram 8002 turntable
This post has 11 Replies | 1 Follower
ktroyh
Posts 20
ktroyh Posted: Sat, Dec 20 2014 4:21 PM
When reassembling my turntable I found a small spring floating in the case. I searched the manual and could not find one that resembled it can anyone help?
Thanks,
Troy
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Sat, Dec 20 2014 5:45 PM
That belongs on the brass screw that adjusts the vertical parallelism of the tonearm.
Lee
ktroyh
Posts 20
ktroyh replied on Sat, Dec 20 2014 6:07 PM
Perhaps that is why the arm is sitting low.
I am a proud new owner of this table and there a few things that have been done by the previous owner  that need to be remedied. At least this part is there as a clue. I fear there might be parts that aren't there with no clues leading to the problem.
Thanks,
Troy
ktroyh
Posts 20
ktroyh replied on Sat, Dec 20 2014 6:12 PM
Lee,
Can you tell me is it the #507 or 525?
Lee
Posts 734
Lee replied on Sat, Dec 20 2014 6:18 PM
507, it goes on the screw.. unscrew it completely and thread the spring over the screw... with the widest end towards the tonearm.. It's a PITA to screw back on though.... much easier with a strong magnetic screwdriver.
ktroyh
Posts 20
ktroyh replied on Sat, Dec 20 2014 6:41 PM
Lee,
Thank you,
Troy
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sat, Dec 20 2014 6:49 PM
I don't think so. It looks like the grounding spring that goes between the deck and the chassis. I have a picture of it on my Beogram 8002 thread.
ktroyh
Posts 20
ktroyh replied on Sat, Dec 20 2014 7:13 PM
Can you link that   thread?
Troy
sonavor
Posts 3,732
sonavor replied on Sat, Dec 20 2014 7:14 PM
I will later. I am just on my phone right now.
sonavor
Posts 3,732
sonavor replied on Sat, Dec 20 2014 7:31 PM
It's halftime at the game so I am able to look up the thread link. Here you go http://archivedforum2.beoworld.org/forums/t/4135.aspx?PageIndex=14
ktroyh
Posts 20
ktroyh replied on Sat, Dec 20 2014 8:00 PM
Thank you Sonavor,
It is likely that is the spring because the deck was off the table.
Troy
sonavor
Posts 3,732
sonavor replied on Sat, Dec 20 2014 11:55 PM
ktroyh:
Thank you Sonavor,
Troy
Yeah, and that spring is cone shaped which matched the one I show. The small end points up.
-sonavor
Page 1 of 1 (12 items) | RSS
