Hi
Just got this for my BeoVision 11:
http://www.rikomagic.com/en/product/showpro_id_56_pid_20.html
Does any have any experience in setting this up to use the Beoremote One?
- Can find it in the PUC list.
If tou could find a similar device in the list on the tv, you might succeeed.
All Android devices are basicly controlled the same way.
Just try some out - can't do any harm.
No one has this little machine hooked up to B&0?
Did you find a solution, am facing the same issue !
I believe the Flirc will work.
https://flirc.tv/
ari:https://flirc.tv/
I use the samsung blu ray puc code of the with the flirc usb-stick. (beovision9/beosystem 3)
Normal 0 21 false false false DE JA X-NONE
My android media center is a himedia q10quard. You can controll nearly everything via the flirc. Standby works but awake not! (the device deactivate the usb port in standby)
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
ari:I believe the Flirc will work. https://flirc.tv/
