PUC for RKM MK902II (Android tv)
This post has 9 Replies | 0 Followers
Ramasjang
Posts 53
Ramasjang Posted: Sat, Dec 20 2014 5:27 PM
Hi
Just got this for my BeoVision 11:
http://www.rikomagic.com/en/product/showpro_id_56_pid_20.html
Does any have any experience in setting this up to use the Beoremote One?
- Can find it in the PUC list.
Millemissen
Flensborg, Denmark
Posts 14,680
If tou could find a similar device in the list on the tv, you might succeeed.
All Android devices are basicly controlled the same way.
Just try some out - can't do any harm.
Ramasjang
Posts 53
Ramasjang replied on Sun, Dec 21 2014 8:24 AM
No one has this little machine hooked up to B&0?
Ramasjang
Posts 53
Ramasjang
Posts 53
Ramasjang
Posts 53
Spinoza
Posts 2
Spinoza replied on Tue, Aug 4 2015 10:37 AM
Did you find a solution, am facing the same issue !
ari
Posts 144
ari replied on Thu, Aug 6 2015 10:19 AM
I believe the Flirc will work.
https://flirc.tv/
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Thu, Aug 6 2015 1:50 PM
ari:
https://flirc.tv/
I use the samsung blu ray puc code of the with the flirc usb-stick. (beovision9/beosystem 3)
Normal 0 21 false false false DE JA X-NONE
My android media center is a himedia q10quard. You can controll nearly everything via the flirc. Standby works but awake not! (the device deactivate the usb port in standby)
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
StUrrock
Posts 995
ari:
https://flirc.tv/
I'll second that
Page 1 of 1 (10 items) | RSS
