Thanks for posting the review. It certainly is in-depth and very long! Good points raised both for and against the A2. Quite balanced and backs up what users have said here on Beoworld - both the positives and the negatives. Interesting to see the hidden port with the cover off. Presumably for updates?
The distortion issue seems to be only with certain types of music - possibly why I have no problems with mine as I don't listen to much with electonic drum machines! The biggest issue does seem to be with the battery life which hopefully with newer battery technology and improvements over time could be resolved. If B&O take note of reviews like this and with comments we send them (they do listen and respond), with a few relatively simple updates, the A2 has the potential to be a leader in the field.
Dave.
Chris Townsend:Exactly Dave, and hopefully with just a little tweaking it will get best in class reviews. Just what Beoplay has needed.
Don't you want a retro brushed-steel and wood edition Chris ?
the A2 does appear a relative of the V1 so I'm glad you're a supporter. lol
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
