I'd like to know how the power adapters are connected to the pyramids?
Are they attached or will I be able to disconnect them?
The reason I am asking this is because I may be able to buy a UK version, but would like to use them in continental Europe by changing the power adapters.
p.
Beoworld app with direct photo upload and emoticons.
BeoNut since '75
Thanks, that's what I thought unfortunately :-(
The power cable is soldered inside the pyramid as you can see in this photo:
but at the other end of the cable (where it enters the PSU) it is actually a connector, so theoretically you should be able to buy just the PSU that plugs into the socket. You have to partially disassemble the PSU to connect the plug, however - not easy.
It's probably easier just to get on German eBay and find a new complete pyramid/PSU - I have bought a few there since moving from UK to Denmark and then Germany!
The newer (non-pyramid) chargers do have a power supply that disconnects at the base of the charger.
