Avant 55 stuttering sound from Spotify source
This post has 17 Replies | 1 Follower
Flere
Netherlands
Posts 345
Flere Posted: Thu, Dec 25 2014 9:25 PM
The in-build Spotify source delivers stuttering sound after some time.
It is not my network connection.
Any others experiencing the same?
- Flere
smile and enjoy the moment
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Thu, Dec 25 2014 11:22 PM
Flere:
I've had something similar with network radio from time to time (on a Roku unit and on an Olive One: I don't have an Avant). I've always assumed that the streaming has started with insufficient buffering and for some reason the buffering has not refreshed and gradually runs out causing the stuttering. A refresh or reset usually gets rid of the problem for long periods.
Graham
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Tue, Dec 30 2014 2:48 AM
Flere:
Yes! I always use Spotify in iPhone/iPad and use AirPlay to MasterLink. But the Avant 55 is not connected to ML and I tried once to use Spotify in the Avant (was doing some cable works in the TV room and wanted some music to listen to). Started the Spotify app. Was good for some minutes but it soon started to be stuttering. Turned it off and has never tried it again.
Millemissen
Flensborg, Denmark
Posts 14,680
I haven't had that with Spotify.
Neither with the 'Spotify' BV source, nor by airplaying from iDevices.
And my internet connection is not fast at all (6 Mbps).
Must be some kind of network/wifi issue.
Aussie Michael
Melbourne, AU
Posts 3,730
I haven't tried spotify yet on my avant.  Is spotify really worth it?  I just normally buy my music and then play from the music I have bought.  I have a free account and will try it.
Millemissen
Flensborg, Denmark
Posts 14,680
If you are as curious as I am, you'll love it.
I like exploring the music of an artist/band/producer, that I already know from some of his/her/their albums *
Imagine you'd have to buy all the albums, that Tom Petty (as an example) has made....
....it would cost you a fortune.
And why would you want to have them locally stored - you can easily re-listen at any time.
I only buy music, that I can't find on Spotify - or special editions (with DVD or nice artwork etc) or multichannel editions.
I buy these as physical media - a download (as compressed audio) is not worth the money to me.
* Some people like to explore other peoples 'playlists' (and/or share their own) - Spotify is perfect for this too!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Dec 30 2014 4:16 PM
Daniel:
Flere:
I've noticed similar behavior in my cable box for TV but never in Spotify but then I don't use a Beovision for it. At times on cable there is an obvious buffering issue, as when you switch to a channel there's obvious video judder, audio is fine. If I hit pause for about 3 or 4 sec then play it is fine. I think on numerous products the initial buffering can be problematic if it takes a while to sync up and giving it a chance to rebuffer helps.
Jeff
Flere
Netherlands
Posts 345
Flere replied on Wed, Dec 31 2014 6:53 PM
Well, after the Deezer app in the Avant 55 stopped functioning I switched to Spotify.
Again 2 minutes into a track the sound is stuttering. Go to next track it starts fine and then after 2 minutes it starts stuttering.
Both Spotify and Deezer seem to be useless at this moment.
The Avant 55 is connected by CAT6 cable to a gigabit switch, just like my Mac.
My Mac report a 180Mbs download performance from the internet, so I cannot imagine my high speed network is the problem cause.
- Flere
Millemissen
Flensborg, Denmark
Posts 14,680
180Mbs download - give me some of that, pleeeease Cool
And if you run Spotify/Deezer on the Mac - what happens then?
ngnear
Posts 245
ngnear replied on Wed, Dec 31 2014 7:51 PM
I can run Spotify all day with no problems. In fact I have no problems with any connections. AppleTV and DLNA are also running well. My Avant 55 is connected via WiFi to the network. It's actually connected to an access point and not directly to the router.
The access point uses the 5 MHz band.
Only very occasionally does the music miss a beat.
Tim
Flere
Netherlands
Posts 345
Flere replied on Wed, Dec 31 2014 8:40 PM
Millemissen:
I have a gigabit ethernet switch and CAT6 ethernet cables.
On the Mac, and even on the Wifi connected MacBook it is all excellent.
Playing Spotify via Modem--> Wifi--> MacBook/Spotify/AirPlay--> Wifi--> Modem--> Ethernet--> switch--> Ethernet--> ATV3--> HDMI--> Avant55--> PowerLink--> BL5 is without problems.
Playing Spotify via Modem--> Ethernet--> switch -> Ethernet--> MacMini/Spotify/AirPlay--> Ethernet--> switch--> Ethernet--> ATV3--> HDMI--> Avant55--> PowerLink--> BL5 is without problems.
Playing Spotify via Modem--> Ethernet--> switch -> Ethernet--> Avant55/Spotify--> PowerLink--> BL5 does not work. After 2 minutes in a track it starts stuttering.
My switch shows a green light for the CAT6 cable to the Avant55, so the connection is fine and the Avant55 is recognitions as a 1000Mbps device.
Maybe my network is too fast for B&O ?
- Flere
elephant
AU
Posts 8,219
elephant replied on Wed, Dec 31 2014 9:47 PM
Flere:
Interesting thought - hold that one.
So is the buffer inside the Avant too shallow compared to the MacBook ?
In other words the stutter is caused by some sort of race condition in the buffer -- data arriving too fast, playing too slowly, and needing to discard parts of the buffer ?
Whereas the MacBook simply caches the entire song ?
How does the MacBook cope for example with an orchestral piece such as a symphony with a long play time ?
BeoNut since '75
ngnear
Posts 245
ngnear replied on Wed, Dec 31 2014 11:30 PM
I don't know if it's relevant, but I have a hard disk installed. I'll check tomorrow if it is used when running Spotify.
Happy New Year!
elephant
AU
Posts 8,219
ngnear:
Happy New Year!
HNY.
Also monitor memory usage.
I think you will need a large recording to validate my theory - hence suggesting symphonic works ...
BeoNut since '75
Amazone
Netherlands
Posts 187
Amazone replied on Thu, Jan 1 2015 1:46 PM
A network cannot be too fast, but it can be misconfigured.
Please try to disconnect your ethernet cable, and connect the Avant via wifi. See how that changes behaviour. Same issues, or none or different issues.
Also, when using the ethernet cabled connection, try to configure your switch port for 10/100 auto duplex. I don't think you are able to configure the ethernet port on the avant manually, so this is the most compatible setting. Best would still be to configure both ends to the same fixed speed and duplex settings. What switch are you using?
Please let us know the results. I do not believe there is a basic issue with the avant spotify or deezer apps.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Amazone
Netherlands
Posts 187
Amazone replied on Thu, Jan 1 2015 1:47 PM
duplicate
Flere
Netherlands
Posts 345
Flere replied on Thu, Jan 1 2015 5:22 PM
Thanks for the suggestions.
There are no settings for the switch. It is fully automatic.
I will do the wifi test in the coming days.
Why I think it is the apps in the Avant is because the home media works fine.
Playing music via NAS--> Ethernet--> switch -> Ethernet--> Avant55/homemedia--> PowerLink--> BL5 is without problems.
- Flere
elephant
AU
Posts 8,219
I did some test this morning on my MacBook using wireless and Spotify.
I ran OS X's Activity Monitor and I could detect no change in Spotify's memory consumption as I played Eroica ...
BeoNut since '75
Page 1 of 1 (18 items) | RSS
DigiCert Secured Site Seal
