Beosystem 3 - Help connecting additional equipment
This post has 10 Replies | 1 Follower
JulianJ
Posts 66
JulianJ Posted: Wed, Dec 31 2014 5:19 PM
Was wondering if any fellow enthusiasts could give me some assistance?
I would like to connect an audio source (iPod) directly to Beosystem 3. I have connected to Av4 & in the 'connections' menu registered the socket as 'unknown STB'.
How do I then select & listen to the source?
Any help would be much appreciated!
Kind Regards
Julian
mjmedlo
Posts 922
mjmedlo replied on Wed, Dec 31 2014 5:53 PM
Did you make av4 a 'source'?
JulianJ
Posts 66
JulianJ replied on Thu, Jan 1 2015 9:28 AM
No, I haven't. Would you be kind enough to explain what to do?
kind regards,
Julian
JulianJ
Posts 66
JulianJ replied on Thu, Jan 1 2015 10:27 PM
Thanks for that helpful suggestion.... I've RTFM & set up the sockets accordingly but get no sound when the source is selected.
anyone have any useful ideas?
Kind regards
Julian
mjmedlo
Posts 922
mjmedlo replied on Fri, Jan 2 2015 2:38 AM
Can you send a picture of the menu selection and connection panel?
JulianJ
Posts 66
Thank you for your help Mjmedlo,
The connections ;
JulianJ
Posts 66
The 'connections' menu;
JulianJ
Posts 66
And finally the settings for 'AV4'. A PS3, Apple tv & Blu-Ray are connected to the three HDMI sockets. An iPod is connected to the L & R phono connections in the 'AV4' panel.
mjmedlo
Posts 922
mjmedlo replied on Fri, Jan 2 2015 3:46 PM
I think the problem is with the calling it v.mem.
The sys3 looks for a video input on it.
Try the 3 way 3.5mm plug with the video output as well as the rca for audio and see if that would do it.
JulianJ
Posts 66
JulianJ replied on Fri, Jan 2 2015 6:39 PM
Mjmedlo,
Success! Thank you very much for your help & suggestions, the yellow phono plug together with a re-boot solved the problem & it's now working well.
Best wishes for the new year,
Kind Regards
Julian
Millemissen
Flensborg, Denmark
Posts 14,680
@mjmedio
Yes - thumbs up
Page 1 of 1 (11 items) | RSS
