Was wondering if any fellow enthusiasts could give me some assistance?
I would like to connect an audio source (iPod) directly to Beosystem 3. I have connected to Av4 & in the 'connections' menu registered the socket as 'unknown STB'.
How do I then select & listen to the source?
Any help would be much appreciated!
Kind Regards
Julian
No, I haven't. Would you be kind enough to explain what to do?
kind regards,
Thanks for that helpful suggestion.... I've RTFM & set up the sockets accordingly but get no sound when the source is selected.
anyone have any useful ideas?
Kind regards
Thank you for your help Mjmedlo,
The connections ;
The 'connections' menu;
And finally the settings for 'AV4'. A PS3, Apple tv & Blu-Ray are connected to the three HDMI sockets. An iPod is connected to the L & R phono connections in the 'AV4' panel.
Mjmedlo,
Success! Thank you very much for your help & suggestions, the yellow phono plug together with a re-boot solved the problem & it's now working well.
Best wishes for the new year,
@mjmedio
