Bought a 4002 turntable recently on Ebay.The only issue that it seems to have is : When you hit the start button to play an album , the tone arm lowers to the beginning of album, and repeatedly skips , not advancing at all.
Check and calibrate the tracking force.
checked and verified, Still skipping, arm does not advance.
Checked and verified. still skipping arm not advacing.
Sounds like the tonearm advancement detection lamp may be out. You can read about the Beogram 400x repairs and adjustments here. That thread references a couple of other good threads like a good one by Beoworld member Beolover here. Those will show you the tonearm detector lamp.
It sounds like a problem with the detection circuit for the tonearm movement. There is a lamp involved for that and it could be burned out. I posted a couple of links about that issue but it is waiting for the moderator to approve my post.
