BEOCOM 2 charging difficulty - problem with charging dock
This post has 3 Replies | 2 Followers
Edsonmorais
Posts 1
Edsonmorais Posted: Mon, Jan 12 2015 12:39 PM
Hi, there!
I have had three Beocom 2 for six years, and they all started to have charging difficulty at the same time.
I bought new batteries, and replaced them.
At first, everything worked well again. But the next day, one after the other, they started to indicate (display) that they needed to be charged.
With a multimeter, I found out that the desk chargers were delivering much less voltage than the right one (5.6 V or 3.6V indicated on the battery set). The voltage delivered was less than 1 Volt.
I than measured the voltage directly from the wall charger (the part that goes directly in the power point on the wall), and found out that the correct voltage was being delivered (5.6V).
So the problem was with the CORD or with the DESK DOCK (charger).
THE QUESTIONS ARE:
1) Does anybody know what I should do? I can't find this desk dock for sale. Actually, the authorised technical assistance company  wants to charge me a fortune to fix it!
2) Does anybody know how to dismantle (disassemble) the desk dock, so that I can take a look inside?
3) Has this happened to anybody else?
Thank you!
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 12 2015 6:23 PM
Edsonmorais:
Hi, there!
THE QUESTIONS ARE:
Thank you!
I have a similar problem.
If I move the phone slightly back and forth in the desk dock, it starts to charge again.
mbee
Paris, France
Posts 1,842
mbee replied on Mon, Jan 12 2015 9:45 PM
Same here since... This week!
GPM
Posts 4
GPM replied on Mon, Jun 8 2015 11:44 AM
Hi there!
I know this is kind of an older post but yes, it did happen to me as well.
You said in your post that you checked the Beocom 2 desk dock and the charger with a multimeter.
Now I'm having a little bit of difficulty with mine and I need to know the polarity for the desk dock charging pins.
Could you please help me by tell me which pin is the positive (+) with the phone facing you, the front one or the back one?
Thank you!
Page 1 of 1 (4 items) | RSS
