I'm trying to connect my BeoSound Essence with my BeoSound 3200. I have only two wireless speakers and want to distribute the music via my link system instead.
Bought a cable at my dealer . In my Essence, I have attached one end of cable to the Ethernet (RJ45) . The other end of the cable is connected to the AUX jack on the BeoSound 3200. When I put on my BeoSound 3200, there is no sound from the speakers. What could I have done wrong? Do I have to make any further setut ? If I instead use my BeoSound Essence stand alone with my two wireless speakers, it works fine .
On the essence put it in powerlink instead of ethernet.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
I am not quite sure, but there might be some settings to be made in the BeoMusic app for the Essence.
When you have/have had your speakers connected wireless, you maybe have to tell the Essence, that it must send the sound through the RJ/PL.
Do check this, in case it won't work first time.
I tried to connect the cable to the PL1-jack on my BeoSound Essence but despite this it came no sound.
After that, I was connecting two BeoLab8000 speakers directly to my Essence through PL1- and PL2-jacks and then it came sound.
