Hi Beo-folks,
Many thanks for all the help I've received so far. I've got my Beomaster 7000 head unit hooked up to some Penta Labs via a set of cables made by Heavenly Audio and it sounds... heavenly!
I ordered a Beolink 1000 remote and I can now adjust the volume, change tracks and enjoy the BeoGram CD I have paired with it. However, I've got two new questions:
Thanks in advance!
-nick
1) To save a preset volume level, set the volume to the desired level, press SOUND and than STORE twice
2) To activate AUX you have to press SHIFT + RADIO on your Beolink 1000
BR
Vintage Bang & Olufsen
the_o_master:2) To activate AUX you have to press SHIFT + RADIO on your Beolink 1000
Or, as always, if you don't have a Beovision TV, configure the Beomaster to option 2. Then you can simply press TV and life becomes so much easier.
(Starting with the Beomaster on standby, press SOUND - 2 - STORE and see that you have some response on the Beomaster's digit display)
--mika
Thank you O Master and Tournedos!
Now my spouse is happy and I am happy
