I just got my Beolit 12 today.
When adjusting the sound from the iphone is is quite the jumps in sound level between two pushes. 1-2-3-4-5-6-7-8-9-10
If I use the Beo4, it is much more sensitive, I can adjust the sound in smaller portions 1-1,33-1,66-2.33-2.66-3 and so on.
Is there any way to make the iphone adjust the sound in smaller portions?
That song is not that great.
I also haven't had any issues with my BL12.
leosgonewild:It has been violently used for a couple of hours
rob08: I think it's a shame that the new Beolit 15 will not include AirPlay support.
How come you are so sure, that it won't?
Millemissen:How come you are so sure, that it won't? MM There is a tv - and there is a BV.
No - and that is my point!
Best wait untill we know the specs.
Millemissen:No - and that is my point! Best wait u ntill we know the specs. MM There is a tv - and there is a BV.
BeoNut since '75
I posted this question recently
http://archivedforum2.beoworld.org/forums/t/13548.aspx
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Looks to be just Bluetooth, and I have to say thank god for that. My A2 has never had even the slightest hiccup.
https://industrycanada.co/number.php?ic=3775B-BEOLIT15&id=180410
http://www.certipedia.com/companies/174322/certificates_by_product?additional_title=Bluetooth+Speaker&locale=en&title=Audio+Device
I considered buying an iPad mini just for the Beolit 12 ,which is pretty crazy but the two items charging at the same time is the only real benefit of the Airplay not functioning !
rob08:I've had my Beolit 12 for around 2-3 years in our kitchen and it has worked really great. Awesome sound for the size, nice design and essentially no AirPlay dropouts. We also use its portability during summers and moving it into the balcony.I think it's a shame that the new Beolit 15 will not include AirPlay support.
I also thought this would be an issue with the A2 but for me it's not. On your iPod / iPhone, I still swipe up, click airplay and then select the A2 which uses BT, so for me its a non-issue.
