mjmedlo:NL to Ml cabling but control is no issue.
There's actually a ML socket on the Beolink Gateway.
I just got one and I am very happy with it. I have no NL products, just ML.
What you need to do is check the Software Version of your ML products. Most of the products can be controlled, but a lot of products need a software update to pass the LIGHT and CONTROL signals from the Beo4/5/6 remote to the Beolink Gateway. But that's the same with the MLGW.
Beoworld app with direct photo upload and emoticons.
We need a good tutorial on the BL Gateway in everyday-use.
Millemissen:We need a good tutorial on the BL Gateway in everyday-use. MM There is a tv - and there is a BV.
