Beolink Gateway
This post has 5 Replies | 2 Followers
lano
Posts 161
lano Posted: Fri, Jan 23 2015 6:50 PM
Does anybody know if the new Beolink gateway can control ML products?
mjmedlo
Posts 922
mjmedlo replied on Fri, Jan 23 2015 7:25 PM
You bet they can.
And usually better!
No problem with Beolink gateway controlling legacy ML products. You'll need the NL to Ml cabling but control is no issue.
PhilLondon
London
Posts 3,637
mjmedlo:
There's actually a ML socket on the Beolink Gateway.
I just got one and I am very happy with it. I have no NL products, just ML.
What you need to do is check the Software Version of your ML products. Most of the products can be controlled, but a lot of products need a software update to pass the LIGHT and CONTROL signals from the Beo4/5/6 remote to the Beolink Gateway. But that's the same with the MLGW.
Beoworld app with direct photo upload and emoticons.
Millemissen
Flensborg, Denmark
Posts 14,680
We need a good tutorial on the BL Gateway in everyday-use.
lano
Posts 161
lano replied on Fri, Jan 23 2015 9:50 PM
Millemissen:
And some documentation like for the MLGW!
mjmedlo
Posts 922
mjmedlo replied on Fri, Jan 23 2015 11:06 PM
https://www.dropbox.com/s/yhe3x5h7lht64k6/Install%20Guide.pdf
Try this
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
