The Moment software version Release Notes
This post has 749 Replies | 13 Followers
Giraffe
Posts 37
Giraffe replied on Fri, Jul 1 2016 6:53 PM
Yes, it says "harvest done" but the content is not accessible thorough the inner ring. However, it is by using the other menus like e.g. Artist.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jul 1 2016 7:37 PM
Giraffe:
And you are sure that the Artists or Playlist you are seeing are from the Twonky server? Not from Deezer?
I would try a power off of the SoundHeart, a hard reset of the JukeBox and a power on to see if it makes the difference
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 1 2016 8:35 PM
Check also that Twonky actually distribute your content.
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Jul 1 2016 9:03 PM
Giraffe:
- resetting the library (surprisingly comes back after a few seconds with a check mark).
This intrigues me, it looks as there is not a good 'handshake' between Twonky server and the Moment. (Supposing there is a reasonably stocked music library on the NAS)
If so it could be the server configuration, network conflict, or whatever...
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Vintage_B&O
Germany
Posts 303
I just checked my software version of the Beosound Moment with the Beotool.
Beosound Moment Jukebox: 1.7.5.1155
Beosound Moment Soundheart: 1.7.399.223963144
Is this version up to date? I wonder, because the version numbers are different.
Greetings,
Mirco
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Jul 2 2016 8:11 PM
MircoHH:
Yes they are
Vintage_B&O
Germany
Posts 303
thanks for the fast answer...
YannChris
Larmor Plage - France
Posts 232
Giraffe:
Exactly the same for me, NAS content is not available on Moodwheel but available in the Artists list.
Sure it is not coming from Deezer, since I have a very limited Deezer collection.
Kind regards,
Yann.
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Giraffe
Posts 37
Giraffe replied on Sun, Jul 3 2016 10:30 AM
Yes, I also can confirm that I have my NAS content under Artists but no content at all accessible through the inner moodwheel ring. The other rings do play content, though.
To conclude:
NAS/Twonky is accessible
Deezer is accessible
The Moment's other user interfaces give me access to both
The beo tool app gives me green light on all categories
However, the inner ring is completely empty
The
I am now clueless since you other guys are reporting that it works again.
Giraffe
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Jul 3 2016 11:16 AM
Giraffe:
What is strange is that (1) I think most of us had issue with Deezer not DLNA source, for me the inner ring was the only one working (2) without Deezer configured you don't have the DLNA content in your inner ring which in this case of configuration should be the only one active .....
Did you hard reset your JukeBox? not sure I have seen an answer to that
YannChris
Posts 232
YannChris replied on Sun, Jul 3 2016 12:12 PM
Giraffe:
 To conclude:
 The
Giraffe
Exactly the same for me.
I did a hard reset of the jukebox (paperclip in the little hoe on the top), did a reset of my Library but it did not help.
My NAS is a QNAP TS-251 running Twonky 8.2.1
Twonky "sees" the Moment.
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Jul 3 2016 1:36 PM
Maybe you could approach the problem from another angle (a complete fresh start from server & Moment). From reading the above, it seems that after several attempts the inner ring still gives an error.
Only one thing is not clear for me between the inner ring and artist view, the ring is not working but you see and are able to play every album of your NAS activating it in the album/artist window. And you are sure its not an album from Deezer. Correct?
Try the following: Power off completely the Moment. Next login to your NAS page, open Twonky server app and give it another name in the Twonky system settings. Per example: if its ServerMusic name it BeoWorldMusic. Best would be to restart the Nas/server after giving this new name, and rebuild your library (you can do that on the Twonky server's maintenance tab page).
Power on the Moment and do an immediate factory reset from within the menu. After Hub and Jukebox are connected to the network and your ready to fill in the necessary questions, skip to fill in your credentials on TuneIn and Deezer (you can do that on a latter base) but point the Moment to the new server name in the DLNA window. Let us know if your albums are now added and if the ring now works after a while (all this without TuneIn or Deezer credentials).
PS.: After the latest update, I experience a longer wait on the rings before actually getting colored, even though the device about menu shows the ok or done marker.
Giraffe
Posts 37
Giraffe replied on Sun, Jul 3 2016 3:04 PM
Thanks Chris, appreciated, I will try that after I'm back from a business trip.
athos
Posts 46
athos replied on Mon, Jul 4 2016 9:38 AM
Hello, I was very happy to read that the tqwo outer rings where working again. After powering up the Moment fresh, on my Moment the two outer rings where working again with Deezer content. Happy? Not! The inner ring does not working again. That was the only ring that was working with music from my NAS when the Deezer problem occured. I don't use Twonky, but Media server from Synology. Worked flawless for a long time on the inner ring. Now Deezer is back on trach in the outer and middle ring, the inner ring is empty. Yes, I cAn find artists from my NAS and it plays also. But only issue is the moodwheel. I am sure that the Moment is connected with my NAS. Ofcourse some will say that I have to install Twonky, but I first want to solve this, because I think installing Twonky is not the solution.
In the beginning very happy with Moment (after BS5). Now dissapointed. My Sonos connected to Line In from my BL vonverter gives me much more fun. Always working.....
athos
Posts 46
Chris
Ostend-BE
Posts 1,170
Chris replied on Mon, Jul 4 2016 10:24 AM
Hi athos,
If you find Artists and Albums from your Synology NAS, it looks the DLNA server is delivering content as it should. Have you been trying to rebuild your music database from within the Moment's menu button?
athos
Posts 46
athos replied on Mon, Jul 4 2016 12:46 PM
Yes, did a reset of the system twice.
Flere
Netherlands
Posts 345
Flere replied on Mon, Jul 4 2016 6:31 PM
I assume the BeoSound Moment must be the worst selling BeoSound system in the history. Anybody know how the sales is going of this product?
- Flere
smile and enjoy the moment
Even more concerning than just being the worst seller is the horrible bugs that are still in the product after 2 years.  The price is also the most ridiculous thing I have ever seen. They need to kill the product now.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Chris Townsend
Qatar
Posts 3,531
When it came out the tablet it uses was pretty old and average then, so they cannot have an infinite stock of those surely. If it's discontinued, will they really persist with the software and Deezer?
I honestly don't know how some of you have the patience. Credit to youErm..
Even IF the damn thing worked PERFECTLY the price makes it the worst decision ever.
For the cost of 1 moment you can literally have these items all to do the same thing plus 1000x more.
A NAS to hold all your music.
about 8 iPads to put in every room of the house.
OR
1 buggy and dated Moment.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jul 5 2016 7:44 AM
Chris Townsend:
Smile
I´ve been with the Moment since the start (even was at the press launch in Las Vegas). I agree its been a bumpy ride and I have been extremely patient, but Moment serves me well. It does what I want it to do, e.g:
- Gather all music sources I need in one spot
- Makes it easy to play music (sure, user interface can always be improved and it probably will be tweaked over time)
- Looks cool (the wood side is still a conversation piece)
- Part of a multiroom experience
I´m not really concerned with the price. Its up to everyone to buy or not buy. That you can buy different stuff cheeper, that does the same thing, is not really relevant, in my mind. You can say that with most luxury goods.
Brigantinus
Posts 140
@ Chris +1
But i found not really an other device, which does the same. You always need a pad or smartphone to control it. I control my moment most of the time with my bei remote and at the moment itself. That was the more or less the main reason, why i bought it. Otherwise the essence would have been the right device.
Brigantinus
Posts 140
i meant @ hiort
Millemissen
Flensborg, Denmark
Posts 14,680
Brigantinus:
That is exactly the main point - it integrates with the B&O network (NL and even ML using the converter)!
No 'NAS/10 iPad solution' can do the same.
But - on the other hand, maybe the supporters of  the 'NAS/10 iPad solution' aren't interested in that at all?
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jul 5 2016 10:38 AM
Brigantinus:
Agree with you. Me neither. Not in a convenient (and nice looking way).
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jul 5 2016 11:09 AM
Millemissen:
And for those like me leveraging WiSA, it's the perfect companion that consolidates many music sources in one small box and streams the sound wirelessly, the product I was expecting to kill the accumulation of iPad-MacBook-Transmitter 1-Hi Fi Amplifier, etc
One day hopefully the software side of it will be fixed, but in the mean time it does the job when MoodWheel or PatternPlay are not the only feature you want to use
Chris
Ostend-BE
Posts 1,170
mbolo01:
We are facing challenges with strength, determination and confidence in the product... however Hmm
I'm perfectly happy with the Moment, if it functions as promised and it already has done. But it is a shame some updates are solving unknown bugs to create new one's which are very well noticeable.
On the other hand, I do not wish to fill my house with a load of iPad's and losing the comfort of easy operation B&O brings us.
Chris:
You don't need a load of iPads. You can buy ONE and it still will do everything the moment does. Everything plus thousands more.
StUrrock
Posts 995
Chris:
[quote user="mbolo01"omised and it already has done. But it is a shame some updates are solving unknown bugs to create new one's which are very well noticeable.
The moment and the BeoMusic software can hardly be considered easy to use. There are far better and easier to use user interfaces out there.
Brigantinus
Posts 140
As i said above: if you wanna use your smartphone and/or a pad, you can choose between 100s of devices. Every manufacturer has a product in it's range (even B&O with the essence).
The moment is just of interest, if you wanna separate your digital music from other electronical devices (with the possibility to use them either). As a moment user it is not of interest, if an iPad can do much more, because the separation is wanted.
You can complain the software bugs, the quiet slow problem solution of some bugs, you don't have to like the interface, but don't complain the concept. if you don't like it, you don't have to buy it.
Giraffe
Posts 37
Giraffe replied on Sun, Jul 17 2016 2:28 PM
I just want to report that my Moment is back to full functionality. I performed a full factory reset which then led to half a day of "harvesting" time. The mood wheel's inner ring now shows my NAS/Twonky content as well as Deezer content after I added the Deezer account as a second step after the reset. My conclusion is that the factory reset is the only way to really rebuild the database as all other attempts like resetting just the library, removing/adding Deezer and Twonky accounts, and even performing a reset with a paperclip did not help to solve the "no content in inner ring" issue.
Thanks guys for your support!
Giraffe
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Jul 17 2016 4:45 PM
Yes - thumbs up
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Jul 20 2016 2:55 PM
This could boost the Moment adoption in the US
https://pyntax.net/index.php/2016/07/19/deezer-is-finally-available-for-all-in-the-us/
Giraffe
Posts 37
Giraffe replied on Thu, Jul 21 2016 8:14 PM
I have to say that my goodwill is now being really stretched: I just discovered that the physical user interface elements like the volume circle and the button on both sides of the tablet are not working any more. The rest of the user interface works - with the exception of the bluetooth connectivity which also stopped working. Very strange also is that I'm not able to reset the tablet with a paper clip any more - regardless of how long I keep pressing the reset button with the clip.
Did anyone had a similar experience and potentially knows a cure? I fear I have to let the battery of the tablet run flat in order to reset the thing.
Giraffe
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Jul 21 2016 9:37 PM
Giraffe:
Giraffe
Never had this issue and it looks like a serious JukeBox failure not related to any software update, a visit to your reseller while the Jukebox has battery life is a must
YannChris
Posts 232
YannChris replied on Sat, Jul 23 2016 6:41 AM
Hello,
Thanks to Mbolo01's advice , I made a total factory reset of the soundheart and a paperclip reset of the jukebox.
Before that, I deleted  my Deezer account on the Moment and disconnected it in Beomusic.
During the configuration process, I did not input Deezer credentials and added my NAS as source, together with Tune-in.
BTW, the connection to Beoportal took a very long time, almost 2 hours.
Then the inner ring was the only working, with music from the NAS, which was normal.
Yesterday evening, after a week of test, I added the Deezer source.
This morning, good surprise, everything is back to normal in the Moodwheel.
Hope it will stay like this.
Kind regards,
Yann.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Jul 23 2016 8:34 AM
YannChris:
Very good news indeed! Bravo
Regarding the Beoportal phase of the reset, I'm "glad" to see that I'm not the only one to be impacted by this delay. This behavior started for me after the 2nd or 3rd software update, I reported this issue to Beodontcare who asked me to contact my reseller as usual ..... and I don't want to spend 2 hours with my reseller to demo the issue.
I used a network analyzer to check what was happening in the backstage, I could see that Beoportal was perfectly reachable, that there was a dialog happening but after that the Moment was not doing anything particular on the network during this very long time, except scaring me the first time it happened. Maybe one day an update will clear the issue, who knows.
Giraffe
Posts 37
Giraffe replied on Sun, Jul 24 2016 7:49 AM
Gents,
I discovered to following paragraph in the Beosound Moment Installation Guide. It looks like the turned off volume circles and buttons is a "feature" that is activated if the reset button on the jukebox is pressed for more than 5 secs.
Shutdown and reboot the BeoSound Moment interface (Jukebox), following these instruction steps: Remove the BeoSound Moment interface (Jukebox) from the BeoSound Moment hub (SoundHeart) so it is not in charging position. Press and hold a thin pointy device (e.g. a paper clip) into the pin-hole for 2 seconds and let go. This will shutdown (Power Off) the BeoSound Moment interface (Jukebox). If less than 1 second no action will take place. (If more than 5 seconds the aluminium touch wheel and the wood touch wheel will loose function; to continue from this situation, place the BeoSound Moment interface (Jukebox) for charging in the BeoSound Moment hub (SoundHeart) and redo all the above instruction steps). Wait 4 seconds. Place BeoSound Moment interface (Jukebox) for charging on the BeoSound Moment hub (SoundHeart) by which the BeoSound Moment interface (Jukebox) will wake-up.
Unfortunately following the instructions to get out of this mode does not help me - maybe I misunderstand it. The essence I got from this is:
Remove Jukebox from hub
Do a 2 sec pressing of the reset button
Wait 4 secs
Place Jukebox back on Hub
Everything should be back to normal
However, this sequence of steps does not work for me. Does anybody else have ideas?
Giraffe
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jul 25 2016 8:59 PM
Giraffe:
Giraffe
Have you tried the 5s reset while the Jukebox is connected to the SoundHeart? This is the way I usually reset the beast.
Page 14 of 19 (750 items) « First ... < Previous 12 13 14 15 16 Next > ... Last » | RSS
