Bought Philips hue
This post has 41 Replies | 3 Followers
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 18 2015 12:47 PM
TWG:
Beojeff, I need your help, too. Big Smile
I can controll the HUE lights from the Beo 4 and 5 but they are not related to any room. If I choose "any room" in MLGW setup, every command works fine. But when I specify a room (e.g. "bedroom") there's no reaction to light commands.
I want to use the red and green buttons of the Beo 4 in any room for simple light on/off commands. So the use of the green button of Beo 4 in the bedroom should ONLY switch on the lights in the bedroom while the use of the green button of the Beo 4 in the livingroom should only activate the lights in the livingroom.
How can I achieve that?
TWG-
I've only used "any room" for my commands. So I'm not sure why your commands aren't working. It seems that they should!
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 18 2015 1:00 PM
TWG-
You might want to check all of you macros to make sure you haven't used those triggers in other macros -- which could cause a conflict. I've accidentally don't and found it to be the reason some macros wouldn't work.
Page 2 of 2 (42 items) < Previous 1 2 | RSS
