Which replacement laser for BS3000 ?
This post has 3 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Tue, Feb 24 2015 5:07 PM
Hi all
Well, so I have gotten hold of a BS3000(model with Pincode) which I had planned for use in my office.. The unit has a defect laser, it will only read some cd's sometimes. As I have changed a lot of these lasers in 2300/ouverture, I just bought the "usual one" from ebay, which is the CDM12.4 laser here
http://www.ebay.de/itm/171650561552?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
However, when I opened the unit right now, the laser is NOT the same in the BS3000 ? The complete unit is called VAU1255/21, and has a laser where I cannot see the chip number because of a metal plate..
The ribbon reads "F8 <> 2" instead of the usual "3067 xx", it has the same connector, and fits in the cd unit, however, I don't think it is a good idea to change it ?
Can anyone confirm if the laser works, or point me in the right direction of a replacement laser ?
Thanx..
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Feb 24 2015 5:10 PM
Just found this thread
http://archivedforum2.beoworld.org/forums/p/10078/89087.aspx
Where it seems that the CDM12.4/5 lasers can be used... But is this confirmed by anyone ?
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Feb 25 2015 8:06 AM
Hmmm, had a go with the CD12.4 laser..
The cd turns 2 times, then just stops, so it doesn't work, or there is another issue. The testmodes show a lot of errors with the CDM12 laser, checksum error and so on.
So I guess that I need to find another laser, or maybe try to change the caps on the servo board ?
Any suggestions ?
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Mar 11 2015 8:02 AM
So after some time of looking into this, I got a hold of some used VAM1205 units from BS9000, they actually have the same laser, and now the BS3000 is up and running again :)
/Weebyx
Page 1 of 1 (4 items) | RSS
