I hope someone know if it is possible to connect two Powerlink-sources to beolab-speakers?
I want to connect one Beosound 9000 and one Beosound 5/Beomaster 5 to a pair of Beolab 5 with powerlink-cables.
Will the soundquality remain the same as if one source was connected? Will it work?
RegardsMartin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Can´t you connect them with masterlink, and set the BS9000 as a slave?
There is a Thing called almando powerlink Switch.
No experiences with it, but I have heard some positve comments on this Forum about it.
Ralf
Hi Guys,
Thanks for your answers. Yes I can connect with masterlink, but I want to know if it is possible to connect with Powerlink directly into the speakers. I hope someone knows.
/Martin
